Question about Dishwashers
I need an installation manual for Kenmore Elite dishwasher 665.13423K701. How can I download a free one?
SOURCE: Kenmore 665 Dishwasher Not Draining
After the first try of our dishwasher the water didn't completely drain. Ever since the same level of water hasn't drained from the dishwasher.
Posted on Jun 17, 2008
SOURCE: Kenmore Elite Dishwasher Problem
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Posted on Nov 10, 2008
rylee_smith
  • 8619 Answers
SOURCE: kenmore 665 dishwasher will not drain
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 08, 2009
ginko
  • 19396 Answers
SOURCE: Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
Posted on May 05, 2009
iwillfixforu
  • 619 Answers
SOURCE: lights do not come on kenmore elite dishwasher
There is a thermal fuse on this model located on the control board. Remove control panel and you will see it attached to the board with 2 wires going to it. part number is 8193762. Hope this helps.
Posted on Feb 24, 2010
Need operate manual for kenmore dishwasher model 16632000
Go to managemylife.com and enter your model number under the "Manuals" tab. The owner's manual and installation manual is available in .pdf format that can be downloaded or printed for FREE. For your convenience, here's a direct link:
http://www.managemylife.com/mmh/owner_manuals/3697/KENMORE-Dishwasher-L0212024?brand_name_search=16632000
If you have any questions, please post back and let me know. I hope this helps you.
Mar 23, 2011 | Dishwashers
Reset sequence for Sears Kenmore Elite 630.1630?
Unplug for 40 minutes to reset this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
Need the model number of the Kenmore Elite dishwasher 1378(2)
The model number will be something like 110.123456
Dec 25, 2008 | Kenmore 13789 / 13782 Dishwasher
Dishwashers Logo
80 people viewed this question
Top Dishwashers Experts
Owen Barnes
