Question about Sony Televison & Video
Power board and main borad in respect of my Sony Bravia LCD 32 S400 A has been burned due to lighning. Iam the resident of Calicut, Kerala. Warranty period has expired , What I want to do?
SOURCE: Power board for 32 in. Vizio
http://www.vancebaldwin.com/
Posted on Dec 21, 2007
SOURCE: PS3 to sony bravia
If you have an HDMI cable hooked up to the PS3 and the TV, you have to set the TV to the HDMI channel.
Posted on Jan 07, 2009
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
  • 52 Answers
SOURCE: sony bravia kld32s4000 32 inch lcd vertical lines
Bad LCD panel if still under warranty have TV service if not you need to replace the panel.
Posted on Nov 14, 2009
  • 51 Answers
SOURCE: I have a 42" Sony Bravia KDL-40S4100
Probable power supply
Posted on Dec 15, 2009
Sony bravia 32" lcd tv won't power up
Crack open your power supply again and take a look to make sure all caps are intact and not blown or bulging. Next check the main board for any possible caps and resistors, not likely as there is an external ps but possible. If you don't see anything odd then there may be an issue with the controller chip in which case you could replace but it would probably work out to the same price as buyin a new tv
May 04, 2016 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My Sony Bravia LCD TV will not turn on.
If no voltages,then replace all main capacitors,power ic and optoisolater ic,do not forget the rectifire diodes/bridge and the output diodes.
Nov 25, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
I have a Bravia Sony KDLV32XBR1, the red light is blinking 6 times then quits and starts over.
Power low of main power supply 10.5V line PLEASE CHECK 10.5 v supply your power supply board is defective
Dec 29, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Got a Sony Bravia 32 L 4000 3 years ago and worked fine untill now. We have a double image , one partly over the other one. Anything we can do to fix it?
No this is what we call a "convergence" problem, it is due to burned out component(s) on the main pcb board. You either will need to get it repaired or replace it, replacing it will most likely be the best option.
Jan 20, 2012 | Sony KDL32L4000 32 in. LCD HDTV
Bravia wont power on
Good day!!!!
TV won't power ON..
This is the common problem..
Power supply board or main board..
Please try this procedure to determine the faulty parts.
  1. Open the back cover.
  2. Check the input of the power supply board it should have 220vac or 110vac depends on your voltage comes from the outlet.
  3. If you don't have voltage input of PSU..Please or try to replace the power cord.
  4. If you have voltage input on PSU..Please check the output voltage of it..It should have 5vdc for the main board,12 or sometime 16vdc for the audio and 24vdc for the inverter board(back-light).
  5. If you encounter voltage drop on the output..Please check the power supply board if have leak/bulged on the top capacitors..Please replace it with the same type,ratings and value.
  6. If the 3 voltages mention above are normal..Your main board is defective you need to replace it because main board is not for D.I.Y repair due to the surface mount type parts on it..
I hope this solution will be helpful..
Thanks for using fixya...
Aug 13, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
Apr 15, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Feb 09, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony Bravia KDL-32V2000 LCD TV switching off and on by itself
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 29, 2017 | Sony Televison & Video
NO POWER?
Ur power IC invertder board it dead.
Need a new one.
Tries the Sony Website buy the power board.
MIght work or some things else might also burned.
Aug 17, 2009 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Sony bravia LCD KDL52 TV: blurred picture with color bands
It is most likely the TCON board (located at the top right against the LCD panel). When these boards have problems, they can act up when cold or warmed up.
You will want to check with any extended warranty company you might have, or Sony's part website for the availability of the TCON board.
The problem here is, sometimes those TCONs are not made available separately and need to be replaced with the screen.
If you have to replace the panel, buy a new tv. You'll save yourself a costly repair.
Jul 14, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
