Question about ASUS M2N68-AM SE2 Motherboard
NO DISPLAY COMING. CONTINUE DOUBLE BIP SOUND. PROCESSOR FAN RUNNING.
    President:
  • 2,351 Answers
Try removing your memory and than reseat it. One DIMM at a time and boot the system in-between each.
Still hear the double beeps? Its possible one DIMM may be defective. Continue.
Clear the bios. See page 1-7 in your manual. When the bios has been reset everything will revert to default settings. The onboard graphics will give you back video. Enter the bios and set the bios so the PCI-E card is used. Save and exit. (Most likely your PCI-E card also needs a power adapter connected).
If the system goes back to double beeps try removing the PCI-E card and than reseat it. (Possible loose connection).
Happy 4th!
Mike
Posted on Jul 04, 2010
D945gccr MB NO DISPLAY I GUESS ITS BIOS PROBLEM
Maltesh,
1) IF ALL of the LED (Lights) were on they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Intel D945GCCR motherboard?
Can use up to an Intel Core2 Duo E4700, (800MHz FSB), according to Intel Support,
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gccr
An Intel Core2 Duo E4700 can use up to 65 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29
Check the Power Supply.
A Power Supply with a weak voltage power rail, will have plenty of power to light LED's, and maybe spin fans, but Not enough power to turn the Processor on.
No processor, no computer.
The computer isn't generating a video signal.
No Signal to the monitor.
Do you have access to a multimeter, or DC Volt meter?
Test the three Low DC voltages coming out of the Power Supply.
A) 3.3 Volt power rail
B) 5 Volt power rail
C) 12 Volt power rail (ALL are DC voltage)
[ In comparison two D cell flashlight batteries store 3 Volts DC ]
Need guidance with testing post back in a Comment.
Or if you have a KNOWN to be good, and Compatible power supply, that you can borrow for a test, try it.
Regards,
joecoolvette
Aug 14, 2012 | Intel Motherboard
Will not power on
if all fan are spin up.
see your RAM, maybe its broken.
a computer need a routine checking all RAM, if its not good, your computer will freeze.
try pull out and put it again. if its doesn't work. replace it.
PS. when you pull out your computer with all RAM pulled out and doesn't heard any BIP BIP BIP (BIOS POST CODE) noise. I can Assume your Mainbpard or ypur processor is broken. maybe its sound scary but its not. see for computer service center to help, they can give you good advice.
May 09, 2012 | HP KT334AA Pavilion Media Center M8530F...
My Toshiba X200 doesn't show any image.I've bought a new motherboard, but still no image appears.The tech that told that the problem was with the motherboard (that was supposed to be burned).Now he tells...
enable what? BIPS? never heard of it in the last 10 years, are you sure you are dealing with a PC tech there?!
Have you tested that the RAM on the computer IS OK?
Have you tested that the Video card on the machine is OK?
has any real troubleshooting been done on the machine?
if he just told you the motherboard was burned without doing any other testing you are dealing with a fraud.
Nov 07, 2010 | Computers & Internet
No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
Remove heat sink,make cpu body.
IF I UNDERSTAND WHAT YOU ARE TRYING TO SAY I BELIEVE I UNDERSTAND MOST ENOUGH TO SAY YOU HAVE VERY SERIOUS PROBLEM AND NEED TO STOP EVERYTHING RIGHT NOW UNTIL YOU FIX CPU!! YOU HAVE SERIOUS OVERHEATING PROBLEM AND ARE PROBABLY CLOSE TO KILLING YOUR WHOLE SYSTEM!! A PENTIUM 4,3GHZ PROCESSOR PUTS OUT A LOT OF HEAT AND THAT IS WHY THE HEAT SINK MELTED, BUT YOU CAN'T RUN WITHOUT REPLACING IT WITH SOMETHING ELSE BETTER THAN WHAT YOU HAD THAT DIDN'T WORK! THIS IS WHY THE WHOLE SYSTEM IS SHUTTING DOWN. IT IS SAYING, IT IS WAY TO HOT TO RUN AND WE ARE GOING TO SHUT DOWN BEFORE WE BURN UP!!! YOU MUST GET MORE COOLING INTO YOUR CASE AND ONTO THAT PENTIUM PROCESSOR AND GET MORE HEAT OUT OF THE CASE. YOU MAY NEED TO ADD ADDITIONAL FANS OR VENTS, BUT YOU HAVE TO REPAIR THE DAMAGE BEFORE YOU RUN THIS MACHINE OR YOU WILL FRY IT!! THE MOTHERBOARD CAN'T TAKE THE HEAT EITHER! REPLACE THE HEATSINK WITH AN ALUMINUM ONE, NOT THAT PLASTIC ONE FROM DELL, AND MOUNT A FAN ON TOP IF NEED BE. YOU HAVE TO THINK COOOOL!!! YOU HAVE THE POWER, BUT IT ISN'T GOING TO DO YOU ANY GOOD IF IT GOES UP IN SMOKE! I'VE BUILT TO MANY MACHINES TO SEE ONE FRY FOR OVERHEATING. YOU SHOULD HAVE AT LEAST FOUR FANS IN THAT CASE, NO COUNTING THE ONE ONE THE VIDEO CARD OR THE ONE IN THE POWER SUPPLY.
DO IT RIGHT AND SHE WILL LOVE YOU FOR IT AND PURR LIKE A KITTEN! NEED HELP-REPLY TO: ARCLIGHT1217
Nov 08, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
I suspect Processor, am I right
If you can, swap out the processor then swap out the power supply, most likely it is the motherboard.
Remove add on pci cards & usb devices and try again.
May 20, 2008 | Computers & Internet
What does the bip sounds sounds mean on my pc
Its probably bad ram chip. Check that it is seated correctly. Then use another PC to do a google search on beep codes and isolate the actual problem by you PC bios type..
May 08, 2008 | Tiny Computers B1996 19" CRT Monitor
H8DAE-0 Fan issues, stopping and starting.
Sounds as if you have a motherboard fault or a processor fault, as, if the processor is faulty, everything will stop, especially if the temperatures arent being read correctly by the motherboard causing the system to shut down before any damage is done.. It's a process of illimination i'm afraid
Aug 21, 2007 | SuperMicro H8DAE Motherboard
ASUS M2N68-AM SE2 Motherboard Logo
218 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
