Question about Hayward Xstream 150 Sq. Ft. Cartridge Filter System W/1.5hp Matrix Pump
Running at 20psi
Pressure is running at 20psi is this ok for a 12X18 oval pool.. and when should the air be released from the filter when it is on or off
  • 640 Answers
If you pressure is low on these pool filters, there are several things that you will want to check. First, make sure that your system strainer baskets are not dirty or clogged. Also, check the suction side of your pump to make sure that there are no leaks. Make sure taht you filter cartridge does not need to be replaced or cleaned. Make sure your pump is properly primed and that the pump impeller vanes are not blocked. Make sure that your strainer basket is not broken to allow debris in.
Posted on Sep 07, 2010
I have jacuzzi fm sand filter pool pump can see that one of the water outlets in the pool is not working as effectively as the other When I turn unit on both gauges flutter out of control and after thirty...
close all the valves on the filter and return line..you dont want any water running out of the pool.. then remove the pump lint pot cover..and the strainer if equipted with one..get pressurized air and blow backwards into the low side pool return see if anything may be blocking those lines..sometimes leaves or floating debris gets past the pump and filter and will collect in some of the underneath joints and passages .. it takes air to release it..like plunging your toilet..
Jan 24, 2014 | Pool & Spa
Pump should stop at 40psi and start at 20psi. pressure does not drop to 20psi but pump comes on immediately when running water. how can I adjust it so that pressure drops to 20psi before pump starts?
You are actually missing air. Your system is water bound. The temporary fix is turn the pump off, drain the tank and start it back up. There is a air volume regulator there that has probably failed.The water you pump has very little air dissolved in it however when it is in your pressure tank; it adsorbed some air from that eventually depleting the air from your tank.
Jul 31, 2013 | PENTAIR WATER - FLOTEC- SIMER FPP1530-P2...
Pump loses power
if impeller is not clogged check on recirculate if ok change sand
Jun 05, 2013 | Sta Rite StaRite Duraglas Pump 1 12 HP...
Reverse direction of electric motor
If your motor runs backwards, you wired the motor backwards. Change your wires around and it will run the correct way.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 | Hayward 1.5hp Pool Pump Motor Motor A O...
My twin tank 2hp comp will run but pressure wont build up pass 20 lbs.
If the motor is working OK but pressure won't go over 20psi you may have an air leak but most probably have damaged piston rings or cylinder or the valve plate is damaged. Check to make sure the tank drain valve isn't open or that you don't have leaks in any of the air lines. If that's OK, you will have to remove the head from the cylinder to check the valve plate and piston/cylinder assembly. The reeds on the valve plate should be flat and not overly discolored (black or blued) from heat. If they are they can warp or get brittle and break. Since your compressor is oil lubricated it is rare for the piston/rings/cylinder to get damaged unless it's run with no oil so check those areas for scoring or damage like broken rings. Replace whatever is damaged and keep the oil full.
Sep 18, 2012 | Dewalt D55151 2HP 4G TWIN COMPRESSOR
High Pressure: STARITE 1.5 hp pump designed to
It is a cartridge issue in my opinion. I dont recommend cartridges ... Sand is so much superior as a filter medial. If this is an option for you ... I recommend it. If not an option, you might be able to get a different type cartridge that will filter at a lower rate and not get as dirty as fast ...
Jul 31, 2010 | Sta Rite Max E Pro 1 12 Hp Up Rate...
Creepy crawly no longer sucks leaves from pool bottom, pump pressure is at 8 only instead of 10.
If pressure is low, problem is before gauge and filter. If pressure is high, problem is filter or piping after filter. In you case it sounds like something is caught in hose or pipes . Could also be something stuck in the impeller. Remove cleaner and hoses and see if pressure goes back to normal. If it does not, check impeller. If it does, something is probably caught in cleaner or hoses.
Jul 30, 2010 | Universal Kreepy Krauly In-Ground Pool...
Compressor will not build pressure
Have you tried adjusting the pressure regulator / also make sure that the over presser blow off is pushed in not popped/ do you hear air leaking ?
Apr 05, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Pressure at 15 psi after backwashing
No that is normal pressure, when the pressure rises more than 10 psi over that in a 24 hour time, you should backwash the filter. Hope this helps
Jul 13, 2009 | Home
I have a Sta-Rite pool filter. In the start up procedure, you are supposed to bleed the air until a steady stream of water flows from the air release valve. Although I have confirmed that everything is...
Hi sstanl, Is your pump output or flow normal back to pool? if there is no water flowing through system you will get no expulsion of air or pressure reading on gauge. If pump is working then you probably have a clogged air release valve and maybe a clogged gauge. Just remove air relief assembly from filter top, remove gauge and clear any obstructions in parts. You should easily be able to blow air thru assy with gauge removed. Teflon tape the components and snug them back in their places. restart your pump and voila! air will come out when prime is established.
Apr 23, 2009 | Sta Rite Sta - Rite Mod Media 450 Sq Ft...
Hayward Xstream 150 Sq. Ft. Cartridge Filter System W/1.5hp Matrix Pump Logo
139 people viewed this question
Top Hayward Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hayward Garden Expert? Answer questions, earn points and help others
