Question about Dryers
My Whirlpool Ultimate Care II (LEQ9558KQ) won't tumble!
has power (I can hear the timer working), but does not tumble. There is no hum from the motor. I think it could be the door switch, but I need to find the service manual for the model to access it.
Thanks for any help!
  • Anonymous Mar 16, 2014
    fuse
    blown fuse
  • 5,911 Answers
Most commonly, this is caused by a broken dryer belt or defective door switch. Toggling the switch with the door open should tell you is it is working or not. On most of these dryer models you should see the dryer drum light turning on and off at the switch is pushed in and released. In either case you will need to open the dryer to access both components. this is accomplished by lifting the top panel and/or removing the dryer front.
If the model number is correct, just follow these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing. The part number for a replacement switch is 3406107.
NOTE: At this point you can access and remove the door switch and replace a necessary. If you don't see the dryer belt wwrapped tightly around the drum, there's a good chance it is broken. Continue on with the next steps to replace the belt.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Roper and refer to diagram H.
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: If you still need a Repair Manual, they can be purchased at Repairclinic.com. This explains how to repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
Posted on Jul 04, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Whirlpool ultimate care ii won't spin
    Possible that the drive is jammed , there is slipping or the motor is faulty. You need to check for free movement after disconnecting the power, if there is friction it must be reset.
    Jan 21, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II gas dryer won't turn off.
    Dryer Won't Stop Running
    • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
    • If you need a new timer the best place ti get it is from Rough River Appliance Repair
    • Phone number is (270) 230-1818 his name is Charlie and he is the best!
    Nov 16, 2011 | Dryers
    Whirlpool Ultimate Care will not stop spinning
    I work on these every day for the past 8 years and have never once seen this problem. If i had to guess i would assume its a stuck contact on the timer. The timer is the only thing that sends power down to the motor but its an expensive guess.
    Hope this helps _MJ_
    Jan 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate care II doesnt' advance through
    Lean washer on its back and check for broken wire from the motor wire harness up the back panel.
    If you find the wire repair it and make sure the wire harness is secure in the provided clips.
    Jan 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II Dryer timer knob
    The timer cam is not aligning the internal switches. Replacing it is the only fix.
    Eric
    Sep 17, 2009 | Kenmore 62602 Electric Dryer
    Whirlpool ultimate care II stops after filling
    Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
    Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
    Whirlpool Ultimate Care II washing maching but will not spin.
    lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
    Dec 03, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Dryers Logo
    541 people viewed this question
    Top Dryers Experts
