Question about Bryant Heating & Cooling
Bryant model 594DNO24-E Air out of vents not cool, fan is not moving on AC unit.
  • 674 Answers
I think you are talking about the outdoor unit so see if you can hear the compressor running. If it isn't running then set the thermostat so that the unit is not running and give the pressure time to come down.(15mins-30mins) Discharge pressure will build up if the fan isn't running and cause the compressor to shut down that's the reason for doing this. After this set the thermostat to call for a/c then see if the compressor is running. If it isn't first check your circuit breaker or disconnect or fuses. One of these should be located close to the outdoor unit. If you have power and it's not running then look at the contactor to see if it is pulled in. The contactor supplies both the fan and compressor. After that then check you capacitor. Some use a double capacitor that works the fan and the compressor. Let me know what you find
Posted on Jul 04, 2010
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
Fan not moving on Bryant 113R AC Unit
bad relay, capacitor, fan motor froze up, try turning by hand.
Jun 11, 2014 | Bryant 463AAC008BA Air Conditioner
Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Sep 25, 2012 | Bryant Heating & Cooling
I have a bryant model 702b packaged unit with 5 wire thermostat wiring coming out of the unit. R Y B G and W. The thermostate in the house is 5 wire and goes to the old central unit and them has a 4 ire...
R-Red is power
Y-Yellow is cool
B-Blue is cool as well
G-Green is fan leg
W-White is usually heat Leg
If you have no indoor unit and this is a ac/gas or
electric outdoor unit try this.
R to R/Red to Red
G-G/Green to Green
Y-Y/Yellow to Yellow
W-W/White to White
-Dont Hook up Blue.
Turn power back on turn the fan to on,fan should run
Turn to Heating, heating should come on
Turn on Cooling,if cooling does not come on switch yellow with blue.
Jul 02, 2010 | Heating & Cooling
I have a bryant AC/heat pump unit. Today I noticed that the air coming from the vents is just warm air, so i went out and the unit in not running condencer nor the fan. (it is the 661cj030-e unit).the only...
YES. It seems your capacitor is bad.
It must be replaced with the exact specifications as the original.
IE: MFD and VOLTAGE for the compressor and fan motor.
Example...35+5 370 vac.
Jun 27, 2010 | Heating & Cooling
Fan outside ac/unit
Hi; are You trying to cool or heat Your house. Also do You have a heat pump...need more info.
Jan 18, 2010 | Hitachi RAS-09UH Air Conditioner
Ac units in apt. is fully charged,but it blows cool to cold air and will constantly run all day with out shutting off. at night when it cools off outside it will run like its supposed to. the fan unit...
Your ac thermostat is defective and not switching off the compressor resulting in excess cooling and need replacement. Also ensure that all doors and windows are closed. Could be some window is opened behind the curtain without your knowledge. That could be yet another reason for your unit continuously running.
Finally check your relay unit and this should solve your problem!
Jul 10, 2009 | Heating & Cooling
AC unit
if its a a window unit suspect a faulty fan capacitor or bad fan motor same with outside, if it ain't moving or turning on the fan is faulty or the capacitor is faulty
Apr 18, 2008 | Bryant 463AAC008BA Air Conditioner
Heating & Cooling Logo
262 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
