Question about Vacuums
Sorry model was H3045 I used it once a year ago I can't remove thetop water container.
    Guru:
  • 302 Answers
have you consulted the manual?. If not here it is. I think it will show you clearly how to remove the water conatiner.
http://www.hoover.com/pdfs/manuals/H3045.pdf
Posted on Jul 04, 2010
I am going to start a small business, which i am going to clean bins. so i am going to use water, so i would like to know where can i get rid of the contaminated water that i am going to use once i have...
I would buy or find a huge water tank and drain the contents into it once its half full por wood shavings or an absorber in to dry it out,or if you filter the water you can use the water for plants,shrubs..
Oct 29, 2013 | Dyson DC27 Total Clean Dust Bin Container...
Dyson filters smell after cleaning
I'm sorry to hear you're concerned about your DC15.
If the filter smells, you may want to take a look at the video below to make sure you're washing it as we recommend. Please use cold water without detergent, and make sure the filter is totally dry before replacing it - allow at least 12 hours. You may find it helps to place it somewhere warm, such as in an airing cupboard, or by a radiator. This should be done at least once every 3-6 months.
This should help, but if you're still concerned, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can provide further assistance.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 08, 2012 | Dyson DC15 All Floors - The Ball Bagless...
Thehow do you clean the black piece n the dirt canister
It is possible to separate the clear bin from the cyclone pack. Open the bin base to discard any dirt in the clear bin, then use the coloured catch on the rear of the clear bin to detatch it from the cyclone pack. The black rubber seal can then be cleaned with a dry cloth, and you can remove any debris from the shroud (the section with the small holes) using a soft brush.
Please note, the cyclone pack must never be washed or submerged in water as this can damage the machine.
I hope this helps - if you'd like any further assistance or advice, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Mar 27, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
My hoover floormate hard floor cleaner is not sucking as stong as it use to. What can I do?
Sounds like the squeegee may be old and need to be replaced. Check that first. If you need a new one you can follow this link.
part number 93001095
http://www.usavacuum.com/h3040-h3044-h3045-s/213.htm
Feb 21, 2010 | Hoover H3044 FloorMate SpinScrub Wide-Path...
Will not pick up water
Hi, Make sure you have the selector switch set to position "C" Wet Pickup. release the trigger. make sure the recovery tank is empty and clean as well as the filter in the top of the tank as there is an automatic shut off valve in this tank. All of these parts are washable and if you have been using it dry it still needs to be cleaned. You also need to make sure it is all back together correctly so it seals. Good Luck!
Feb 02, 2009 | Hoover H3045 Vacuum
Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Oct 20, 2008 | Bissell 9200 Upright Vacuum
Hoover Steam Vac Dual Rinse Model F7205-910
MOST COMMON PROBLEM IS THE ATTACHEMENT VALVE IS BROKEN WHERE YOU CONNECT FOR WATER ON SIDE OF MACHINE. THESE MODELS USE AN ELECRONIC SOLONOID TO ACTIVATE WATER TO NOZZLE IF IT IS COMING OUT THERE SOLONOID MAY BE BAD
Mar 27, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Bissell 1697w Powersteamer
I have a similar model and occasionally have problems with water/detergent flow. I find it is generally due to an airlock in the piping caused by forgetting to turn the deregent water control off before removing the detergent container. Follow the manual instructions. Turn the knob to off. Fill both containers. locate them carefully. Make sure filters in the water tank and in the flow meter are clear. Start machine with handle laid flat and knob turned to maximum flow.
Dec 22, 2006 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
12 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
