Question about Dryers
My friend has a old ge dryer and it has no power will not turn on
  • 10,319 Answers
Remove the door switch and jump the wires from it. If it turns on the switch is at fault. If not go to the start switch and do the same
Posted on Jul 04, 2010
Old dryer turns but does not heat, so bought a new one the same thing happens, can it be the electric plug?
A plug is easy to change, You can do it your self, Just make shure you turn your breaker off, Before you remove the old plug,Follow the wires on the old plug, End connect them to the same terminals on the new plug.Allso you can Write it down where they go,Before you disconect the wires from the old plug, Try the cheap route first, End that is to replace the old plug,
Oct 18, 2012 | GE GTDP490EDWS 7.0 cu. ft. duradrum...
I have a ge ge dbr453eaoww dryer it is about 5 years old and working fine till now. i push the start button and nothing happens i know ther is power to it the light inside turns on do you have any ideas ?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2010 | Dryers
The dryer is getting power but the barrel isnt turning
If motor runs but no tumble, belt is broken. It broke due to overloading, old age, or bound up tension pulley or drum support wheels. You have to check all of these when replacing belt. Belt is fairly cheap.
Jul 02, 2010 | GE Profile Harmony DPGT750EC Electric...
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Iam hearing scraping sounds from my dryer.
Hello Friend, Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim.
Jun 25, 2009 | GE DBSR453EBWW Electric Dryer
My GE dryer (3 years old, electrical) is heating too much (outside) and not performing properly. I was told that it could be related to the duct. A friend told me that I have to call a company to clean the...
my dryer did the same thing The problem wasn,t lint it was the cord. It might be the right fit just the wrong amp and if its to much the dryer will get to hot you can get a new cord at most hardware stores or just the plug on the end of the cord. I hope this helps it fixed my problem.
Jun 04, 2009 | GE DVLR223 Dryers
GE dryer does not run and just hums
Yes, open it. You'll probably find a broken or loose belt.
More help?, let me know.
May 09, 2009 | GE Profile DPSB619ED Electric Dryer
GE dryer: DPXQ473ET5WW
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
I tried to get it for you!
The model # DPXQ473ET5WW is not coming up at GE! How old is the unit?
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | Dryers
Ge dryer shuts off
turn the drum by hand see if it turns fairly easy if it does then you may need to replace or clean the drive motor if not may need to service the tub rear bearing tub glides etc
Dec 30, 2007 | GE DBSR453EBWW Electric Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
