Question about Whirlpool GEW9200L Electric Dryer
Heard load pop sound and smelled something burning. Now my dryer starts but drum does not turn and the belt around drum still looks good. what else could be the problem
  • 958 Answers
SOURCE: drum won't turn
it came off the tensioner or it is broke. pull the belt and see if it is not broke. if it is still loose around the drum, then it just came off the tensioner.
look at the manual on how to put back the belt with the tensioner.
tnx 4 using fixya,
drcool
Posted on Sep 16, 2008
  • 19 Answers
SOURCE: kenmore gas dryer 417.92042101
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Posted on Nov 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 15, 2008
SOURCE: dryer wont heat up and just heard a pop and smell electrical char
called an appliance fix it guy-was the heating element
Posted on Mar 25, 2009
Maytag317
  • 1136 Answers
SOURCE: Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Posted on Jun 01, 2009
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
Kenmore gas dryer won't turn
It sounds like the belt is stretched or slipping. The belt needs to be replaced. It has been a few years, but dryer cabinets haven't changed that much.First, unplug the dryer from the electical outlet. If the lint filter slides out the top, then remove the two screws that you see in that top door. Pop the two front clips and open the top like a clamshell. You should be able to see where the belt goes around the drum. The front is held on by a couple of bolts at the top of each side. If you remove them the front will swing out, but be careful with the door switch wires. Before removing the old belt, pay attention how it goes around the motor tension pulleys. Slide the old belt off and slide the new one on. Reassemble. I hope this helps
Mar 28, 2010 | Kenmore Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Dryer was running with full load of clothes. Heard a loud pop twice, ran back to the laundry room and smelled like something burning. Turned dryer off, and now it won't start back. Also, the very top of...
Well it sounds like a sound I have heard... forgetting that I had a cigarette lighter in my pocket and having it explode from the heat in the dryer. But you say you heard two loud pops?
Once everything cools down, check again and report back... does the dryer not turn on at all? Does the light come on when you open the door? Does it buzz when you push the start button? Stuff like that.
Jul 27, 2009 | GE DBXR463EDWW Electric Dryer
Frigidaire dryer quit
sounds like the motor unless something is stuck in the blower housing such as a sock
Jul 13, 2009 | Frigidaire Dryers
Screeching noise and burn smell how do I open dryer to repair
Pull it out from the wall, unplug it and remove the back panel by removing the screws. The problem is most likely the belt around the drum which is either worn out or out of alignment. Take a look at it and decide if you can just straighten it on the drum or if you will need to buy a new belt.
May 01, 2009 | Dryers
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
My dryer drum stopped turning. The dryer will turn on
it does sound like the belt is broken. you will need to access the inside of the dryer by removing the front. they all come apart differently. Make and Model would help me tell you more.
Dec 26, 2008 | Dryers
I have a kenmore series 80 dryer model 110-70812990 that i heard a bang then the drum stopped turning and i smelled burning rubber. I'm guessing that the drive belt broke. How easy would that be to repair...
Remove back of drier after disconnecting the power cord. Find old belt laying on floor under machine. Obtain new belt and place around drum and motor pulley. done
Fisher Paykel Elec. Dryer
Usually the belt is a single piece that wraps around the entire drum. The fact that you smelled something and that you feel the clothes are not being tossed tells me that the belt was slipping on the pulley of the motor that drives the drum. This will heat up the belt causing the smell. If the belt gets too loose, this will happen. I'd replace the belt, and I think you'll be back in action.
Let me know what happens. Please rate accordingly.
Sep 18, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
66 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
