Question about Dishwashers
When I push the power button it beeps but doesn't turn on the light is on with the time setting. I cleaned out the drawer the bottom drawer works. Help.
  • 298 Answers
What is the model of the dishwasher? Make sure the supply water tap is open.
Posted on Jul 04, 2010
DW (top drawer) will not start.Green light comes on when pushed to start but after 1-2 minutes, DW starts beeping and start button light turns red.
Turn the mains power off and back on after a little delay. If no change, some sensor in the drawer is faulty - most likely the drawer close sensor as it is telling the controller the drawer is not closed.
Mar 23, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
No power top drawer
Try to reset your dish washer. Turn off main power supply and leave it for at least 1 min. Is there any error code appear/beeping sound?
Sep 09, 2007 | Fisher and Paykel 24 in. DD603H W Built-in...
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Although when i press power it doesn't work ?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Jun 08, 2012 | Sony VAIO VGN-TX670P/B Notebook
Hello, I have a Fisher and Paykel DD603I and both drawers have a red light on the play/pause button and won't stop beeping. Can you please help me with a solution to this problem?
It sounds like the dishwasher is in flood mode. You would need to dry up the water in the base pan and test. The link below is a video that explains how to repair your fisher paykel dishwasher.
Fisher Paykel Dishwasher Repair Video
Mar 23, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher & Pykal Dual Drawer Dishwasher. Suspect after young child played with control buttoms on top drawer the power won't come on. Bottom Drawer works perfectly. Have tried turning unit off at power...
Press and hold the key or lock button for 5 sec or till you here a beep to unlock. Or till the light goes out above the lock button. You can get your manual here just find your dishwasher.
http://www.fisherpaykel.com/dishwashing/
Good luck and please rate
Sep 16, 2009 | Fisher Dishwashers
Flood switch
I had the same problem and I fixed mine. It wasn't hard at all. First, make sure power is off either unplug or shut off breaker. Next, open the lower drawer and on the sides toward the bottom you will see a circular recessed pin with a flat slot. Without forcing, wiggle the door down. When you get it off you have to remove the wire harness, just unplug it. Now, on the sides at the bottom, you will see where the drawer fits on the slid rail. Push the plastic button slightly to release the lock for the slid rail to the drawer and push the slid rail all the way back as to release the drawer fronm the rail. Be carefull when you release one side as to hold it up still while removing the other one. Now, flip the drawer on its side and try to get it as far out of the way as possible to the right of the unit. You will now notice a plastic cover at the back left of the unit. This is where the flood swith is. Remove this cover by sliding to the right. The will be water under the circuit board you see. Soak up as much as possible and you can use a hair dryer to get the tough spots. Now try to find the resson for the water. I had a mouse living under mine. Look for a break in one of the hoses. After all dried up turn power back in before reinstalling lower drawer. If dried properly, the dishwasher should stop beep beep beeping. Now turn water back on and run upper drawer. Inspect hoses again. 50/50 chance. If now water, reinstall lower by replacing plastic cover, place drawer on rails and slide all the way back. It should click back in if on rails correctly. Now install the door face, line up tabs into drawer, and slide up. Align holes for recessed circular pins and just push them in. Test lower. Thats all I got, Hope it helps.
Oct 03, 2008 | KitchenAid 23 in. KUDD01DPPA Stainless...
My Fisher and Paykel dishwasher will not keep running.
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the door is open or closed. Wipe these areas with a clean dry cloth...Give it a try
May 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
Top Dishwashers Experts
