Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Loses power & smells like burning. I'm worried the motor is burnt up. the belt looks fine.
  • 276 Answers
If the belts are intact and the brush roller is rotating and the problem persists, the machine should be inspected internally at an authorized Service Center. Go to www.bissell.com under the Customer Support tab and enter your zip code under Service Center search.
Posted on Jul 06, 2010
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
After a few minutes, vaccum emits a burnt rubber smell. Checked the V-belt and it seems fine.
It might seem fine but the burnt rubber smell means that the belt is slipping. This causes friction between the belt and the motor spindle causing the spindle to get extremely hot which melts the inner surface of the drive belt.
Take the belt off and examine the inner side that loops over the brushbar and the motor spindle. You will find that there are sections where the belt has partially melted - they are usually smoother than the rest of the belt.
Belts don't need to break before they need replacing. They just need to lose some tension. This is what seems to have happened in your case and you should replace your belt.
Regards,
BElectric
Dec 17, 2010 | Vacuums
I replaced the belt as I have done before on Self-Propelled Vision. When turned on it is very loud and left on too long will smoke and you can smell the belt deteriorating. I do not feel this is a belt...
The best way to check if the motor is burning or not is to go back into the unit and take the belt off of the motor shaft. If the unit does the same thing and burns or even if the lights flicker when the unit is on, then it is definitely the motor.
Usually the burning smell associated with this is like a burnt match or burnt wood.
good luck.
Nov 19, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
Corner of the rug sucked in and the roller now does not spin
If you can't hear the motor running, look for a reset button which may have tripped. If the motor runs, remove the belt and look for a burned spot that might be preventing brush turning. Replace it if it is. Make sure that the wall outlet has power (check with a lamp). Hope this helps!
Jan 04, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum cleaner makes a burning smell
spark is from brushes not to worry it's normal but you should change the belt
thumbs up
Aug 17, 2009 | Vacuums
Dirt Devil Jaguar Bagless Upright Burning Smell
take the belt off again you will see burnt rubber from the old belt stuck to the motor shaft.you can take a fine piece of emery cloth and clean the shaft down to its polished finish.always good to do this after each belt.check the brush roller and see if there are any signsd of plastic melted.make sure it turns freely if not the brush roller might be siezing uo on youhave you cleaned the hepa filter?does it smell like wires burning or rubber.with it unlugged take it apart to the motor and take a fine iece of emery cloth and go over the motor armature .then try it again.you can take all the filters out and run it without the filters.that will help you narrow it down.please leave feedback
Mar 15, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum shuts off and has a burnt smell
Try removing the drivebelt, and try running it to test like this. The brush bar will not turn, but it should function normally without smell at this point. If it doesn't, you may need a new motor as I think the brushes may have worn down - producing an electrical type burning smell.
If it runs fine without the belt attatched, then there is probably a build-up of hair or threads at each end of the roller stopping it turning freely. With the hoover off, check it turns freely and easily. A small metal nail file or similar is usually a good tool to clear it.
If the roller is stiff, the belt will not turn easily, and overheat on the motor spindle - causing the burning smell.
Jan 08, 2009 | Hoover Vacuums
Burning Smell coming from the moter
This could be a motor problem. There is always a slight blue arcing that occurs when an electrical motor runs and can be visible through the exhaust vent, but any excessive arcing indicates a problem. If the carbon brushes are sticking, this will cause excessive arcing and can be corrected by an experience service person, but if there is any electrical failure, the motor would have to be replaced. There are no parts available for these motors and the expense of replacing an armature (the likely culprit) would be more than the motor. This could also be as simple as a worn belt, but usually, belts will not produce the smell your describing. When a motor is burning out, it will produce an acrid odor that will linger for a long time.
Feb 23, 2008 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
131 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
