Question about Proview PL713S 17" Flat Panel LCD Monitor
Screen is blank
When the power is turned on, the icons on the screen will come on for about 5 seconds then goes blank. When this is repeated, the same thin occurs.
I switched monitors to ake sure that the problem did not exists elsewhere. The new monitor worked fine.
Please help me.
Thanks
Ralph
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 05, 2010
Lg 50pq6000 screen flashes on then goes blank
Might want to contact LG to see if there is a firmware/software upgrade for this issue as it sounds familiar to me.
Apr 30, 2012 | Televison & Video
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
Screen goes blank when first turned on, have to keep restarting m
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Monitor goes blank after 5 secons
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | Computers & Internet
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
The screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
BRAVIA KDL-V32A12U PICTURE LOSS
THREE Blinks
B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FIVE Blinks
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Open Questions:
See all Proview PL713S 17" Flat Panel LCD Monitor Questions
Proview PL713S 17" Flat Panel LCD Monitor Logo
70 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
