Tv has gone wrong
Tv prob
My TV when i switch it on it had a halo shape in the middle with purple pink faint rainbow colours and has made the picture grey with bright pink colours on things like lips and certain other items on the screen.
Buy new one
Posted on Apr 17, 2008
The colours on my Wharfedale 350 tv have gone wrong. Everything is green and purple. How do I fix this.
The problem is AV cables or connectors on the TV, try to replace the connector shouldwork
Mar 04, 2012 | Televison & Video
Tv has picture but blurry almost double picture but not quiete also has oval shape purple colour bottom center
for blurry picture,try rotating your antenna or repositioning it,as it is caused by reflections of signals.
for the purple spot,try shifting yur TV to another place in the room or repositioning it.
Aug 23, 2010 | Televison & Video
Got a rainbow line in the middle is this the picture tube the tv is 5yrs apex tv
HI,
ITS NOT PICTURE TUBE PROBLEM ,,
ITS PROBLEM WITH COLOUR CAPACITORS WHICH INSIDE TV,,
APPROACH TECHNICIAN..
TNKS
RABBANEES
Nov 11, 2009 | Sony KP-57WS500 57" Rear Projection...
The colours on my tv have gone pink and green
Either your picture tube has gone bad or the transistor or IC on the crt board, on the picture tube, that feeds the blue gun has gone bad. You would have to test the transistor to see if its shorted or open with a multi-meter, or check the voltages to and out of it. The voltages are around 200v and dangerous if touched, best left to a proffessional. If its the transistor/IC it would be a cheap and easy fix by a repair shop, if its the tube, you may want to go tv shopping.
Aug 30, 2009 | Goodmans W280NS Television
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Purple spots on the bottom and middle of my EPSON livingstation tv.
Search for this problem by using the term "pink bloches" I already explained the solution.
Oct 28, 2008 | Epson Livingstation LS57P2 57" Rear...
Color problem with TV
Are you getting Green or purple or pink patches all over the screen?
This could be a problem of Degaussing. Have you placed any Magnetic source near the TV recently? Some Tape recorder or walkie talkie or a Speaker, etc? The Magnetic field created by any of the above sources can cause coloured patches over a colour TV screen.
It also happens if you shift the TV from one location to another.
The third possibility is that the Picture Tube's Red Output stage gone faulty. Unless you are a trained Solid state Electronics Technician, there is nothing you can do. Better go for a trade in.
Feb 22, 2008 | Panasonic CT-27G21 27" TV
Tv broke
Please, give us a better description of exactly what you see on the screen.
Aug 20, 2007 | Samsung PCJ522R 52" Rear Projection...
Picture problems
My computer did this and I think my TVs just gone the same way. Was definitely a loose connection somewhere. In the computer monitor it was because the pins in the plug were slightly bent and if I moved the wire the picture got better. In the end I had to replace the connecting cable
Mar 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
