Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
After 5 days using saltwater system water is cloudy. Before installing new system no cloudy water. Help.
  • 297 Answers
Intex salt water system does not keep your pool cleaner. It is only a means to not have to buy liquid or tablets
If your salt is not at 3000ppm not below 2700 not above 3800 you will not generate enough sanitizer ( chlorine )
You need a good stabilizer to help hold chlorine content and a good non foaming algecide which you would use every 5-7 days
Don't forget chlorine consumption is caused by many factors.
# of swimmers, heat, sun, rain, did any one sneak in with sun tan oils and so on and the worst thing for a pool is to not use it on a daily basis.
Get your money back on the salt system and go with what worked for you.
Posted on Jul 04, 2010
  • mark Gianotto Jul 16, 2010
    It would be nice of you to use the rating system after being helped
Cloudy/green
super shock pool with chlorine it will just maintain
Aug 11, 2013 | Intex Automatic Salt Water System for ...
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
Can i use a sand filter with the intex krystal clear saltwater system?
Yes you can.
The saltwater chlorinator is connect to the outlet water pipe from the sand filter before the water returns to the pool.
Depending upon the model of the saltwater chlorinator It may need to be mounted horizontally or vertically, check with the installation instructions..
Apr 11, 2012 | Pool & Spa
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
Cloudy water after running system for 15 hours
yes ... do you have filter media insyalled and the proper amount of salt installed?
Jul 03, 2010 | Intex Automatic Salt Water System for ...
We switched to the saltwater system and the water is cloudy
hello way too much for me to type if you want to call I can go through it have a pad of paper and pen ready
Mark
586-625-2300
Jul 19, 2009 | Intex Automatic Salt Water System for ...
We switched to the saltwater system and the water is cloudy after 2 days
DID YOU USE POOL SALT, MINE STAYED CLOUDY FOR 2 WEEKS AND FINALLY CLEARED UP , I USED THE WRONG SALT , 25LB BAGS OF TABLE SALT FROM SAMS CLUB
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Code 93 saltwater system
Hi, Code 93 is telling you that the system is done running, did you mean to say it said 92? That code would be for too much salt. If indeed it is a Code 92 you are getting, give Intex a call, or email. I have found their website to be very helpful, they have a F&Q's area. Good luck!
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Ph level is high cloudy water
Chlorine generator systems gradual increase the water's pH. You'll need to add acid to keep the pH down around 7.4. High pH can lead to cloudy water so get the pH balanced and you should be ok.
Jun 14, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
672 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
