Question about Kenmore Elite 45986 Front Load Washer
Water leaks from under washer and when machine done, pool of water
  • 5,911 Answers
If your Kenmore FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
The manufacturer recommends that you leave the washer door open between washes to prevent the seal from becoming permanently stretched. Once the seal stays compressed constantly it can stretch and not seal properly. In addition, leaving the door open helpd let the wash tub air out and prevent mold, mildew and musty odors.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Posted on Jul 04, 2010
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
Water Inlet Valve Replacement Procedure
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
Jan 20, 2010 | Kenmore Elite 45986 Front Load Washer
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
2003 Whirlpool Duet Washer clear water pooling in drum after use.
When the machine is off, there are only two ways water could possibly enter. 1 Check the drain hose install, that it is not installed deep in the standpipe, if the hose is shoved too deep, it can sometimes siphon (rare with front loaders) water back into the machine.
2. Most likely cause, a slow leak from the water valve. Sometimes the water solenoid will not close completely, and you will get a very, very slow leak into the machine.
If not the drain hose, try shutting off the water supply valves when done using the machine, if that takes care of it, you may want to replace the machine's inlet valve.
Apr 19, 2009 | Whirlpool GHW9400SU Front Load Stacked...
I have a Hoover Washer HNF 1617 that is leaking water underneath.
You may have the threads for that strianer cap crossed or its just loose. First, try tightening it if it still leaks use teflon tape or pipe dope to seal it. there isn't much pressure there...so it is definitly repairable. At worst you may need to replace the drain pump.
Mar 13, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
AWM8143
FA is the emergency shutoff switch that detects when water is pooling underneath the machine -> a leak.
"Check float switch under machine, empty any water from catchment tray, check for water leaks or oversudsing".
Jul 10, 2008 | Whirlpool AWM8143 Front Load Washer
Water Leak
When the machine has filled TURN THE POWER OFF.then tip the machine back & lean it on the wall, look around for the leak it should be fairly easy to see. It may be the door seal which has split, you should be able to see this be examining the seal with the door open
Oct 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
171 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
