Question about GE AJCQ08ACB Air Conditioner
My air conditioner keeps freezing up
Hi my air conditioner keeps freezing up and and wont blow cool air some times what can i do? do i have to buy a new one or can i fix it at home?
  • 47 Answers
Probably 75 to 80 percent of all air conditioner service calls are repaired by simply cleaning the coil fins. If it is a window air conditioner, unplug it from the wall, remove the front cover and brush the coil fins using an up and down motion. Next go outside and brush the outside coil the same way. Then blow through it with water. Too much water pressure can also bend the cooling fins. The inside coil if extremely plugged up can be washed also but it will be necessary to remove it from the window to do so. If this doesn't solve your problem, chances are that it is either low on freon or the compressor is weak. It may be time to look for a new one. I hope this helps
Posted on Jul 04, 2010
Hi. I need help fixing my urka-a042jk10e Air Conditioner please. It's not blowing any air up thru the vents and my house is 97 degrees!
Possible that the compressor is not running. Call a service tech. Could be a run capacitor bad, stuck reverse valve or even a shot compressor.
Jul 30, 2016 | Heating & Cooling
Ptac153b50am not blowing hot air
Have an identical unit. Replaced the heater core which has built in limit switches. Didn't fix. Finally fixed it by replacing the heater relays (small black boxes soldered into the circuit board). Can purchase at Digi-Key online for $4 apiece or buy a new circuit board for about $100.
Jan 04, 2013 | Amana PTC153B50AM Split System Air...
Kenmore window air conditioner model 580. Blows air but nott cool air. wont cool the room.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 02, 2011 | Kenmore 76129 Air Conditioner
Wont blow cold air all the time just sometimes
heatman101
Jul 23, 2011 | Kenmore Single Room Air Conditioner
Compressor wont start..blows hot air
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | LG LP1200DXR Portable Air Conditioner
Air Conditioner not blowing cold air . I cleaned the filter. What is wrong?
cleck the coils if they are dirty the system wont cool is the compressor running when the coil is dirty it increases the head pressusre or lower the suction pressure does it freeze up
Sep 13, 2010 | Frigidaire FAX052P7 Compact Room Air...
MY WINDOW UNIT LEAKS WATER ALL OVER MY FLOOR AND BLOWS WARM AIR. I CLEANED IT AND IT STAYED COOL FOR A WEEK AND IT FLOODED AGAIN.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Your unit is freezing up...check the air filter...
There are many things that can cause your air conditioner not to cool…
heatman101
Sep 03, 2010 | Premier Heating & Cooling
My A/C blows out hot air every couple days
The only problem I could think of is that the air conditioning needs to be recharged as they call it because over time it will run out. You can usually go to a place like Firestone and they will do it (depending on how much you need) for around 100 or you can find a way to do it yourself you would buy either R134A or Freeze 12 that might be harder to get but cheaper
Aug 19, 2009 | Whirlwind FH-778 Air Conditioner
Air conditioner cools a bit but not like it has to
you have to keep the condenser fin clean at all time.
vaccumn it.
Jul 01, 2009 | Danby DPAC8020 Air Conditioner
GE AJCQ08ACB Air Conditioner Logo
235 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
