Question about LinxCel SW-221 2 Port USB 2.0 Auto Sharing Switch KVM Switch
Installed SW-221 now USB port shows Unknown Device - can't update driver
I installed the Linxcel USB 2.0 Sharing Switch, now my printer is not recognized by the computer. Device Manager shows the USB port as Unknown Device and no driver loaded. I attempt to load the printer driver but get a message that it can't be updated. I have uninstalled the the USB switch software and plugged the printer in direct, but am having the same problem.
  • wmessina Aug 04, 2008
    I have 2 Dell gx150 desktops connected through a sw-221 to a hp psc2210v all in one printer.Printer shows disconnected on both computers,no matter what I do. Running a straight cable from either computer to the printer bypassing switch, printer works ok.thank you
    wmessina
  • Anonymous Nov 05, 2008
    same thing...works when plugged up directly, not through the switch
2 Suggested Answers
SOURCE: KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Posted on Sep 15, 2008
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
I have a Hp 6500 wireless which does not get installed through usb or wireless both ....kindly help....
Title: have a Hp 6500 wireless which does not get installed through usb or wireless both
At first try to connect through USB
  • Just connect your printer data cable into the USB port of the Computer
  • On your printer
  • Then Right Click on My Computer select Manage then Go to the Device Manager and Click on Update Hardware Option
  • After updated you see a Icon as yellow Question Marks with The name of your Printer.
  • Just Right Click on it and select Update Driver
  • Do as per the given Direction.
After successfully install your driver you just restart your computer. Your printer now installed with your PC
If you are connect through wireless
  • At first on your wireless device of your pc and on your wireless switch of your printer.
  • Go to the search new device option from computer where icon of your wireless device will be show in the start bar.
  • After completion of searching your printer will be detected and Right Click on that and update Driver.
May 05, 2011 | Computers & Internet
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
My pc won't detect my printer, my printer is brother dcp 150-c
have you connected the printer's USB port to your CPU? If not, then do so. If after doing it, still your PC don't detect your printer, make sure you have a functional USB port. To check it, try using a USB Flash drive if it works with your PC. If it won't, you might have to "Enable" your USB at your BIOS.
Regards!
Jul 09, 2009 | Office Equipment & Supplies
I-ball digital pen tablet - usb port - unknown device
i ball tablet comes with a driver cd.. uninstall your usb unknown device and install the driver..it should work properly..
else connect to internet and update your diriver..
as for 2000 the same procedure will work...
Jun 08, 2009 | Computers & Internet
Pop up message says that I have a USB device that is not recogniz
Do you have anything like a printer or scanner or an external USB drive connected to the computer. If yes, then remove it. If not let me know.
May 14, 2009 | Toshiba Satellite 5005-S504 Notebook
Problem yet not solved i.e usb not detected on any port and without usb installed, an unknown device is indicate,
Is the USB showing yellow mark on Device Manager entries. When you connect any device to USB does it show any device??
If not, then it might be the USB chips failure on your MoBo and need to replace.
Otherwise, go to Intel support site and download all the updated drivers for your MoBo.
http://downloadcenter.intel.com/
Feb 24, 2009 | Intel Motherboard
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Canon Image Class MF4150 Drivers
pls i want to copy for cd the driver about the photocopier ( canon multi function 4150) to install to the pc
Nov 11, 2007 | Canon imageCLASS MF4150 All-In-One Laser...
LinxCel SW-221 2 Port USB 2.0 Auto Sharing Switch KVM Switch Logo
269 people viewed this question
Top LinxCel Computers & Internet Experts
David Payne
David Payne
Are you a LinxCel Computer and Internet Expert? Answer questions, earn points and help others
