Question about Bogen Communication GS35 Amplifier
Amp. Power light comes on but no soundalso does fan come on even if you give no volume?
Fan should allways come on.the light just tells you the line is plugged in.double check your speaker/input, and all common sense checks.if not, take it to the shop.preamp or output transistor problem.
Posted on Jul 05, 2010
Technics stereo Integrated Amplifier SU-G75 powers up few seconds then overload light appears and a clickng noise coming out of metal boxq with tag FP-3 M V RTP1P5C015 on it iis it supposed nto make c
If the receiver works at low volume, but goes into OVERLOAD and shuts down at higher volume, it means you are player the unit too long and too loud. Try yo keep the volume down to a reasonable volume.
Nov 15, 2014 | Audio Players & Recorders
Marshall MB4410 - Dies and comes back to life every few minutes..
Our bassplayer had the same problem with his mb4410. As it turned out, the fan was not working when the amp got hot. It did turn when cold - go figure! Swap the fan for a good quality (Pabst, Sunon) 80mm pc fan with 2-wire connection. Three or four wire fans will not work w/out modding. See your local pc guy and ask for an unregulated, silent 24/7 fans. He will know. Our bassplayer sold the P.O.S. while still in warranty. HTH.
Apr 26, 2010 | Marshall MB4410 Bass Combo Amplifier
Subwoofer Turns Off when volume is turned up
check your earth from the amp i had same prob and the vibration broke earth connection once secured it was fine
Aug 24, 2009 | Pioneer TS-SWX310 Car Subwoofer
When I turn the volume up even a little bit, the protect light comes on and stays on
Hiya,
Try disconnecting the speaker cables, then turn it up and see if it protects. If not, then connect one speaker at a time (on very low volume otherwise could pop the amp) and see if you can identify a faulty speaker/channel. Then try a known working speaker on the amp channel that is giving problems (to eliminate a fault with the amp). If the known working speaker also trips the amp, then it is that channel faulty. Hopefully you get away with a bad speaker wire though!!
Best of luck
Jul 15, 2009 | JVC KS-AX4550 Car Audio Amplifier
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Amplifier sound difficulties
When I turn on my marshall amplifier its makes this unusual, anoying sound. it sounds like a small motor or a fan going. the sound of the amp is good but its just makes this motor sound when I switch it on. can you help me find the problem.
Mar 25, 2008 | Prime 40 Watt 2 Channel Lead Electric...
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Bogen Communication GS35 Amplifier Logo
113 people viewed this question
Top Bogen Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bogen Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
