Question about Philips Magnavox Learning Universal Remote
Vizio code for universal philips remote? - Philips Magnavox Learning Universal Remote
5 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
freetek
  • 5568 Answers
SOURCE: Can't find codes for universal remote -- purchased for Vizio TV
Unfortunately, there does not seem to be any truly 'universal' remotes and we have two that won't 'learn' from the originals either. They should be called 'multibrand' remotes.
Use your Vizio model number of your set and try here:
Remotes
This seems to be the best site but they are also not infallible.
Posted on Nov 30, 2008
SOURCE: i have a philips universal remote code-cl043 and
I just move and lost my code sheet for my phillips universal control is there some where i can get some codes,i have a emmerson television thanks.
Posted on Oct 02, 2010
What is code for Vizio TV?
Your Philips remote is universal so you can use its code search feature to find something that can handle some or all functions of your Vizio TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Apr 06, 2016 | Philips Phillips SRP1103/27 3-Device...
How can I use universal remote with my Vizio TV?
Apr 06, 2016 | Philips Televison & Video
Can I use your remote universal Llz414
Here is the Remote info
  • VIZIO Universal Remote Setup ' VIZIO www.vizio.com/remote-setup Point the VIZIO remote control at the ... Click the following link to view a complete listing of codes to program your universal remote. ... TV; Audio; VIZIO ...
  • Universal Remote Codes - Vizio cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf · PDF file UNIVERSAL REMOTE SETUP ... Find the programming code for your TV (or device) in the ... Point the VIZIO remote control at the device and press
  • Vizio Universal Remote Codes - TVremoteCodes.net tvremotecodes.net/vizio.html Vizio Remote Codes for TV, DVD, VCR, ... Uverse Remote Codes; Comcast Remote Codes; Dish Remote Codes; Universal Remote Codes; Apple Remote Control; ... VIZIO ...
  • The company started in 2002 as V Inc. by William Wang, Laynie Newsome, and Ken Lowe with $600,000 and three employees. In 2006 the revenue was estimated around $700 million, and in 2007 it was estimated to have exceeded $2 billion. VIZIO is known for aggressively pricing their HDTVs against major competitors.[2]
  • On October 19, 2010, VIZIO signed a 4-year contract to sponsor college football's annual Rose Bowl game in Pasadena, California, beginning with the 2011 Rose Bowl presented by VIZIO and ending with the 2014 VIZIO BCS National Championship Game.[3] When the Rose Bowl contract ended, VIZIO signed a contract to sponsor the Fiesta Bowl making the official name the VIZIO Fiesta Bowl.
    As of 2012, VIZIO has over 400 employees.[4] About half work at its headquarters in Irvine, California, in engineering, design, sales, and operations, while the other half are employed at a call center in Dakota Dunes, South Dakota.[4][5]
    VIZIO also manufactures its products in Mexico and China under agreements with ODM assemblers in those countries.[6]
    Her eis
    Dec 31, 2015 | Vizio L32 32 in. LCD HDTV
    What is remote control code for 42 inch vizio tv with phillips universal remote
    Your Philips remote is universal so you can use its "code search" feature to find a suitable code. The codes are stored in the remote. If a thorough search does not produce a code, you may have to try another universal remote because not ll codes are stored in all remotes.
    Oct 07, 2014 | Philips Phillips SRP1103/27 3-Device...
    Need universal code for a phillips remote
    There is no setup code for Philips remote with Vizio TV> Anyway, check this code. Good Luck.
    {0081}
    Oct 13, 2012 | Vizio 42 in. LCD TV
    What's the code to program my philips universal
    0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
    Mar 26, 2012 | Philips Televison & Video
    Code for phillips universal
    Hi
    Im not sure if this is the correct phillips remote.
    I assume you know how to input the code?
    This should be the one for your Vizio TV - - > 709
    Here is a PDF page with all the information on how to input the code and what you can do if it doesnt work.
    http://www.remotecodelist.com/remotes/philips/PM335_Codes.pdf
    You could do a code search which will go through about 300 different codes until it finds one that works with your TV.
    I hope this helps
    Mike
    Jun 10, 2009 | Philips PM3S Remote Control
    I HAVE RCR312W REMOTE AND NEED CODES FOR PHILIPS TV .
    0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0081 1149 1154 0288 0456 0003 0008 0068 0075 0086 0087 0141
    Feb 12, 2009 | RCA Universal Remote Control
    I need universal remote code
    waht is the exact renote your using? brand and model
    thanks
    tom
    Dec 20, 2008 | Philips Magnavox Learning Universal Remote
    Vizio Code for Philips Universal Remote
    Think 0002 will work. If not a GOLDSTAR code should work,
    try them.
    Oct 25, 2008 | Vizio L32 32 in. LCD HDTV
    Philips Magnavox Learning Universal Remote Logo
    716 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
