Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
How to change the spool in the black and decker grasshog
  • 903 Answers
Is this the cordless Grass Hog? Turn the trimmer upside down so you're looking at the bottom. There are two orange tabs on either side of the spool -- push these in and the head should pop up so you can pull it out.
On the new spool, feed the cord out several inches and stick it through the hole in the trimmer where the old cord stuck out. Then pop the spool into the cavity so that the orange cover faces out (toward you). Pull the cord taut and make sure it is not long enough to hit the plastic guard. If it is too long and it touches the guard, pull the spool off and wind the cord in a little bit. If the cord is too short, pull the spool off and thread out a little bit more length and try again.
Turn the trimmer right side up and turn it on to make sure it works. If you hear a loud rapid thumping sound that sounds sort of like a machine gun, the cord is too long and is hitting the plastic guard.
Posted on Jul 04, 2010
4 Suggested Answers
  • 3 Answers
SOURCE: changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Posted on Nov 19, 2007
SOURCE: Black & Decker Grasshog GH600 lever replacement
this has been driving me crazy. try this pdf from the black and decker site http://support.blackanddecker.com/cgi-bin/blackanddecker.cfg/php/enduser/fattach_get.php?p_sid=98uDbvBj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=1885&p_created=1148586888&p_olh=0
Posted on Jun 28, 2009
vincob
  • 718 Answers
SOURCE: how to string spool for black and decker corless
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Posted on Apr 08, 2010
What replacement line is used for the BLACK & DECKER Grasshog. 5,063,673 5,620,336 6,443,753 6,443,762
For the cordless Grass Hog, the replacement spool is AF-100. You can purchase these spool heads online or maybe find them at your local hardware store, but they may be hard to find because the Grass Hog is not made any more.
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
Battery to fit Black & Decker CST20000 Grasshog weed eater. Where can I buy just the battery or battery pack?
Unfortunately, the battery pack as a unit has been discontinued, but the battery itself (part #243213-00) can be purchased online. Amazon sells it for $35.99. You can find it here:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
May 20, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Black and Decker Grasshog auto line feeder just spits line out non-stop. Tried lots of things but nothing seems to work.
I'm gonna take a guess and say you re-spooled the line yourself. If you did you may have put too much line on the spool. The max. is 30', but I've found that that can cause jamming, which forces out more line, if not done perfectly. Reduce the amount of line by about 5 feet and you should be OK.
Apr 10, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
How to replace line on the double sided spool for my grasshog
HOW TO REPLACE LINE, PLS CAN YOU SHOW ME FROM THE PICTURES.
Oct 14, 2009 | Black & Decker 14" Grass Hog Xp...
Black and Decker Grasshog Malfuntion
Make sure to look at the spool. There should be an arrow showing which way to wind the string...Good luck...Lee
Sep 16, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
1,261 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
