Question about Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver
Tuning knob doesn't change channels like it did. Punching in the channel number doesn't change the channel properly either. Can I purchase a new receiver and transfer my license to the new unit?
3 Suggested Answers
SOURCE: xm2go direct entry tuning problem
You have it set on a preset mode now. On the unit or the remote control press the "pre/dir" button a few times until you see the word "DIRECT" at the top left of the screen next to the antenna strength. From "direct" you can then key in the channel numbers directly to go to them.
Posted on Dec 26, 2008
TOLhamRadio
  • 509 Answers
SOURCE: Car cradle works "wirelessly" with
Must be in a CAR cradle - won't work in home cradle, & you cannot plug into audio/headphone jack or FM transmitter will turn off. okay? Let me know.
Posted on Oct 07, 2010
My 54cm RC-A07 Logik Tv is not tuning and displays a red asterisk next to channel number in top right hand corner of screen
Hi. This might indicate that your TV is eiter in "channel " mode or in "number" mode. Channel is rhe real channel from the transmitter, (being 2-62, S channel) while the number is the one you change by your remote. There must be a way in the menu/tuning where you choose between both.
Oct 06, 2014 | Televison & Video
Can not change channels by pushing channel numbers
Sounds like you don't have the tuner wired properly, IF you have a stand-alone tuner, then you need one wire to a continuous 12VDC for memory, the other 12VDC that's hot in accessory position, and then the ground. IF you hook the two 12volt wires together and they're only on when the car's on, then you will lose your memory of what channel it's on. Also, when you turn the radio off, turn it off with the BUTTON - not just by turning off the car. Give it a try using the radio's POWER BUTTON for on and off, NOT just the ignition, then it will remember the channel most of the time. Okay?
Jun 26, 2010 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Channel numbers above 13 do not come in. This started after a power failure. All numbers are received on another TV at that site. How do I program the stations that should be received?
Go into the TV's setup screen and set the tuning mode for "cable" or "CATV". It got set back to "air" after the power failure. When set for off-air tuning, only channels 2 through 13 tune properly. Set for cable and rescan channels and you'll be set.
Apr 07, 2009 | Televison & Video
Sony WEGA 42" LCD Rear Projection TV It won't change channels up or down with the remote or the buttons on the television.  It will change channels with the number pad on the remote but not the channel...
Hi, it sounds like your saying that punching in 08, 09 etc. works but channel up button won`t switch from 08 to 09 correct??? If so you need to go into your tv`s menu and "autoprogram" your channels into memory, video-tek
Jan 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
DTV converter box INSIGNIA
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu.
Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna.
On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point.
Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel."
Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels.
Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4.
When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again.
However, be sure to avoid standing in-front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up!
I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held.
The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set.
Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up.
I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search.
From this FixYa web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to apprear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Dec 03, 2008 | Insignia Digital-to-Analog Converter for...
Tube radio tuning thread slipping
The dial cord may will likely need replacement, good luck finding anyone who can do it. There are some chemicals ("non-slip" from GC) that might be applied to the cord at the dial or at the tuning capacitor, but I would recommend that this be done by a tech.
Aug 23, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Channel Programming
Is this an U.S. made tv? or are you using a universal Sony purchased outside the U.S. If it was made here, then you probably have a bad tuner.
Feb 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Quasar vhq41m
Hi , set remote to auto program set enter /on sreeen will appera then stop if no channel appear ,then select channel.
Jan 21, 2008 | Quasar VHQ400 VHS VCR
Changing channels
Put the channels in memory by selecting CATV and then auto-program in set-up menu...................................T.
Dec 15, 2007 | Proscan PS27108 TV
Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver Logo
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
