Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Disengaging blades when mowing completed
I have a 15.5 hp 42in deck craftsman rideon lawn mower I am having problems disengaging the blades when done mowing the only thing I've done to try to fix problem is lubricate moving parts on the mower ie pulleys, bearings, blades any suggestions?
    Scholar:
  • 38 Answers
The cam plate that the tensioner pulley is mounted on that rotates back around to tighten the belt as the cable or rod is engaged is likely rusted and worn, there is a bushing in this pivot that can be removed and cleaned fairly easily with a abrasive wheel or pad and lubricated upon reassembly.
Posted on Jul 04, 2010
Blade does not stop spinning when lever disengaged.
Under seat of tractor theres a plate that says model # it looks like 917. 000000 i need that # please and i can help you with the problem it sounds like the belt isnt disengaging which will cause blades to continue to go.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
42 inch Craftsman blades won't engage
model 917258862 mower was given to me. sat outside numerous years. I've managed to get it to start run and drive, but cant get blades to engage. don't know what the wires are for or do that go to some sort of pulley attached to the bottom of motor. can somebody help me pls ?
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The blade engage lever on my 42" craftsman mower will not disengage completely
Get a can of penatating oil and spray the pivot point of the idler arm on the deck. That's the one that moves back and forth when you lift the blade engagement lever.
Jun 06, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Sputtering Mower
It might not be disengaging the mower deck all the way off. I had this problem on an older model.
May 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
517 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
