Question about HP Compaq Presario SR1820NX (ER919AA) PC Desktop
Mouse not working during first boot , if I reboot the system then it is working fine. this means that during cold booting mouse is not working
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 107 Answers
It may be just due to loose connection of ur mouse wire. better remove the RAM and remove the dust by just rubbing wit eraser and reset it. and aso Check whether your mouse wire is connected properly. Even then the problem is not solved, better give for service
Posted on Jul 04, 2010
How to remove black screen from my laptop
If you have a repair disk, boot from it and run a "Start up Repair". On a Dell machine I think it's "F10" during the boot process to get to the BIOS settings, change the setting to boot from CD to run the repair. After running the repair, reboot and enter the BIOS again, change the setting back to boot from the Hard Drive, save and exit. Hopefully this will solve the issue.
Feb 16, 2013 | Dell Inspiron 600M Notebook
How to rebut comuer
if you mean reboot computer
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
Jun 15, 2012 | Computers & Internet
USB mouse block the POST
Sounds like it is trying to treat the mouse as a boot device. Check the bois under boot devices and try to disable booting from USB. If this works, and you need to boot from a USB device at times, go back into the bios and re-enable boot from USB. Then change your boot order.
Hope this helps
Jan 13, 2012 | Foxconn K8M890M2MA-RS2H Motherboard
I have a worm in my computer. How can I format the disk?
if you format your hard drive you will need to load another operating syatem on on it
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
Hope this helps
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
if you still want to load another operating system
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Jun 20, 2011 | Fujitsu Siemens (MAN3184MCB) Hard Drive
Hi after installingceative lab soundblaster 5.1 my acer 8930 screen does not work,,,it works on external monitor and i have had problem before but problem seemed to sort its self out when after many...
or
Also you might try
May 18, 2011 | Computers & Internet
Black screen after turn on
That "Blue Screen" is also known as "Blue screen of Death".
The problem is due driver compatibilty or unstablity.
Try to boot your system to "Safe Boot" by pressing F8 during startup.
Select "Last know good Configuration that works"
Check if it can take you to desktop.
Unstalled the wi-fi driver and reboot.
If the above procedure fails, again
Select "Safe boot"
Now create a restore point  and download the lastest version of your WI-Fi driver and installed.
This should work fine.
Otherwise Backup all your important data from your hard drive (mainly opearting system file installed drive usually C:\) and go for a new Installation.
Dec 28, 2009 | Acer Aspire One PC Notebook
Will not start up and blue screen pops up with fatal system error
try booting into safe mode
tap the F8 key during boot up and select safe mode,
attempt a scan disk, virus scan (avg works in safe mode)
then reboot, if it works, fine no problem sometimes windows has a hiccup during booting,
otherwise if you have recently installed anything (including drivers) try removing them in safe mode and booting back to normal windows.
if all else fails windows reinsallation may be required
Sep 23, 2009 | Gateway Computers & Internet
Intel Dual Core 2.0 GHz Sytem hangs after boot
During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
Computer can't find mouse...
Well your problem sounds like a unique one, however, I can tell you exactly when you're computer looks at your mouse. When you push the power button the computer goes into the POST mode (Power-On-Self-Test). This is a good minute before you see the Windows login. During POST the processor is detected, how much memory, what hardware is recognized and whether BIOS has Plug n Play. After POST the boot process starts, during the boot process there is a file called NTDETECT.COM, it is used to detect any hardware that is installed and adds that information into the Registry..there are some other files but it does not pertain to your problem. After boot is when you hear the beep on your computer, the one beep is saying all is well and ready for the operating system. So it sounds like your mouse is not being detected either during POST or when NTDETECT.COM runs during POST. Here are some steps you can take: First you must replace the mouse to test its electronics. If the replacement mouse works, the original mouse was defective. If the replacement mouse does not work then the original mouse's electronics are good. In this case the mouse driver or the port hardware is the problem. Find mouse in Device manager, uninstall driver, then reboot see if the Plug and Play picks it up. Update and re-install drivers. If the drivers don't work then its the motherboard, go back to the PS/2 mouse. Hope this helps. Let me know how it goes.
Jan 04, 2009 | Logitech Cordless TrackMan Wheel...
Boot Manager
Did you enable USB Legacy support in the bios?, if not, that should fixit
Sep 06, 2008 | ViewSonic ViewMate CW2206 DHCW2206...
HP Compaq Presario SR1820NX (ER919AA) PC Desktop Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
