Question about Craftsman 25cc Gas Line Trimmer
Weedeater starts ok but as soon as you tilt it downwards it shuts off.
  • Roy Cagle
    Roy Cagle Jul 04, 2010
    Typically, Weed Trimmers run in any position (when nothing is wrong) due to their carburetor design. This is quite puzzling in nature. Any other details like how it runs or sounds as it is shutting off.? This may be an electrical problem and a wire is loose somewhere.
    Problem Solver:
  • 19 Answers
The fuel line in a trimmer usually has a weighted fuel filter so that no matter which way you tilt it, the weight pulls the filter down toward the pool of fuel in the tank. If this weighted fuel filter gets caught or stuck in one corner of the tank, then it won't fall properly in the tank to the fuel level so it then runs out of fuel. Look into the fuel tank, with no fuel in the tank, and make sure it moves freely when you roll the trimmer around.
Posted on Dec 13, 2010
Line on crafstman weedeater
wind it in the other direction.
Aug 10, 2017 | Weedeater Garden
Weedeater riding mower with briggs and statton 19 cc 875 series engine won't turn over like its locked up. was running fine shut it off for 5 min and started back up and as soon as I went to engage the...
check oil level. Most likely no oil. If no oil, it ran, then got hot and as soon as you truned it off, welded itself to everything. You have a big boat anchol.
Aug 04, 2014 | Garden
Do the basics, check the battery voltage first. If there is not enough battery voltage present when you try to engage the blades it will certainly die and may not start until the battery is either charged or replaced. There are other items to check but do this first.
Hi, recently my a/c window unit starting making a water sloushing sound then started spitting ice. Is it dying?
What you are hearing is a water buildup in the drip pan under the unit. This is caused by a clogged drain hole and/or not enough downward tilt on the rear of the unit. The rule of thumb is 1/4" to 1/2' rear downward tilt. This allows the water to flow to the rear of the drip pan and out thru the drain hole. The spitting ice, is from the fan blades hitting the water in the drip pan. Turn the unit OFF & unplug it. Then check and adjust if necessary, the things I mentioned above. Aslo, be sure that the air intake filter remains clean.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Maytag M7D24E7A Air Conditioner
The unit starts to drip water inside the house down the wall of the window that it is in
What you will need to do is reposition the window unit to where it is slightly tilted downwards in the rear so that the water flows out the backside.
Jul 06, 2011 | LG Goldstar GWHD5000 wall/window Air...
Stihl FS85 Weedeater
I suspect carb. trouble. Is the compression OK? Look at the spark plug after trying to start it. If it is wet, you are getting too much fuel. The white smoke indicates that. You may need to overhaul the carb.
Go on the Stihl site and customer service for information.
Sep 17, 2008 | Garden
Craftsman 25cc Gas Line Trimmer Logo
555 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
