Question about Ameri Shred AMS-3000 Shredder
Manual guide shredder ams 3000
Manual guide for shredder ams 3000
  • Boricua29 Apr 17, 2008
    I need a manual guide for shredder ams 3000
  • 32 Answers
Heres a few sites that have gears and parts
another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
Posted on Sep 01, 2009
When turned on shredder runs, dose not stop when items are finished, but must be turned off manually. is there anything I can do to fix this?
stuck ,faulty reader switch or debris is blocking or covering the sensor unplug unit and carefully look and try to clean any paper or debris in shredder
Aug 11, 2016 | Shredder Office Equipment & Supplies
Searched for manual for Royal VF1000ms shredder
I am reading your statement and there is no reference to any personal document on what I am reading
I am guessing that for the download of the pdf file it asked you on the left hand side at the bottom to run or drop down arrow to save and run
it may have gone directly to your c drive in your personal documents
if it has been stored there you may be able to recover it by clicking on the start button icon and under the programs list in the search box ,type in the different details of the pdf file and search
Jul 15, 2015 | Power Motorcycles
Just purchased shredder and it seems to work in reverse but not on auto.There was a small basket looks like it hooks on to something I don't see where.This basket is not shown in the manual.
Question: have you inserted paper to shred while set on AUTOMATIC?
In most units, there is a sensing switch (electronic or mechanical) that allows it to run.
Jun 06, 2015 | Honeywell 9112 Twelve Sheet Cross-Cut...
Ativa shredder manual
Are the shredder blades going around? most shredders have guides that guide the paper between to shredder gears or teeth. these guides are usually made of plastic and breake. First step is to see if the shredder gears or teeth ar going around.....
Sep 23, 2013 | Office Equipment & Supplies
This is my THIRD ROYAL SHREDER which I BOUGHT FROM Sams Club I discarded the other two because I could not resey them. Can you tell me how to reset this one? I LIVE IN HOUSTON TX. Is there a repair...
If you have gone thro 3 shredders I am guessing you are using them wrong.
Firstly..shredders bought at Sams or Costco or any Discount store are "Consumer" shredders and are meant for light duty use. Think of it...you spend $45.00 or $50.00 on a shredder and most "Professional" business class shredders START at a couple of hundred dollars...so realise what it is you are buying first.
Secondly, ... most of these shredders are cross-cut shredders which means they require regular lubrication with shredder oil...if you dont do this, you will have the shredder sieze-up in short order and you will burn out the motor or PCB inside ...OR BOTH.
Lastly... the biggest failing of people who use shredders is that they put TOO MUCH paper in the cutting blades. As a guide ....If the manufacturer ( dosn't matter if its Royal, or Staples, or whoever..) if the manufacturer says the machine will do a MAXIMUM of for example 12 sheets...that means that 1 more sheet and it JAMS. The more you jam a "consumer" shredder the more you are likely to break plastic gears or blow circuit boards. "THIS IS A FACT." The best advice I can give ( as a person who has repaired shredders for over 20 years.) is that you make sure you only put 70 ~75% of the max rating given by the manufacturer into the cutting blades at a time.
Regarding getting your machines repaired...contact ROYAL at 1-800-524-0799 and they should be able to give some assistance as to who can help. Good luck!
Mar 01, 2011 | Royal Office Equipment & Supplies
My 5550 shredder is completely dead. Is there a manual/guide to removing the covers. How do I get to the power circuit?
Open the door and look up towards the bottom of the shredder head and find 4 Phillips screws to lift the cover off.
Oct 16, 2009 | Quartet gbc Shredmaster 5550X Confetti-Cut...
Destroyit 4104 manual
I know that shredderparts.com has parts for it, but I don't know about the manual for this machine.
Aug 21, 2009 | Industrial Paper Shredders IPS16D
142 people viewed this question
Top Ameri Shred Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Ameri Shred Office Equipment and Supply Expert? Answer questions, earn points and help others
