Question about GPS
I have a 2002 mazda 6 and the AT light is coming on .. I did the scan on the vehicle and got two codes. U0101- lost comuication with TCM U0073 - Comunication Error Bus A off I need assistance in pin pointing what is my problem
  • Davea Mohammed Jul 04, 2010
    I did check the grounds and all were intact
  • 10,319 Answers
Check you grounds from the battery for a tight connection. Poor grounds do develope these codes
Posted on Jul 04, 2010
My 2006 Miata has a U0101 LOST COMMUNICATION WITH TCM
Leave this to the experts, very complicated testing with a special electronic scan tool must be done.
Sep 06, 2017 | Mazda Cars & Trucks
2005 Mazda 6 4cylinder codes u0101 & u0155
Common problem with several causes including bad ground wire or bad tcm/pcm. Highly recommend you check one of the many mazda forums for specific details
Aug 28, 2016 | Mazda Cars & Trucks
What should i look for when getting engine codes u0121,u0101,u0155,u0073,u0100. plus all lights on clusters on. some times car only goes 5mph till i shut off and restart.
All these " U " codes are communication issues amongst modules. These modules communicate on bus wiring from one to another. You have a communication issue with one or more modules. You will most likely have to have the vehicle proffessionaly scanned with a vehicle scan tool to be able to identify the source of this communication issue. You may have a bad module/wiring/power/ground issue to be repaired
Nov 29, 2015 | Cars & Trucks
How do fix TCM and ECM
Hello, It is not just a simple answer to your question of fixing tcm and ecm Depending on the issue you with the TCM or ECM you will need all the proper tools and maybe the Mazda software. even if you have all these things, you still need the knowledge on how to use them or you can damage the ECM TCM very easily. If you have an OBD2 scan tool then you can scan the codes and clear them. The light should go out. If it comes back on then scan the codes again and post them here. I will tell you what you need to do. The code will start with a letter then four numbers, like this P0301 or P1611 or something like that. I am here to help, -Tim
Mar 30, 2015 | 2004 Mazda 6
What do these codes U0100, U0155, U0101 and P2187 mean for my mazda?
U0100 - Lost Communication with ECM/PCM "A"
U0155 - Lost Communication with Instrument Panel Cluster (IPC) Control Module
U0101 - Lost Communication with TCM
All of them are Geniric Codes 4 Mazda, I would say who ever was working on the car last, posobly forgot or missted 1 or 2 connection
plugs along the way near the last repairs. So just trace yr last steps 2 see if ther any unpluged connectors, cos looks like they all are part of same chane in that line.
P2187 - Sys To Lean at the idle Bank 1
Hope that helpes you. Good luck.
Tony D:-)
Aug 03, 2014 | 2004 Mazda 6
I have dodge charger 2012 trouble code U0101 Lost communication with TCM
it is under warranty. unless you installed a radio, alarm or remote start.
May 09, 2014 | 2006 Mazda 3
Toyota codes u0100 and u0101
U0100 means lost of communication with ECM/PCM
U0101 means lost of communication with TCM
Feb 24, 2014 | 2007 Toyota Camry
Mazda 6 2005 u0101,u0155,u0121,u0073,u0100 codes coming up
I got the same problem. u ever figure it out? ive cleared codes and there the same. light on cluster lit up . plus some time after pulln away from stop car goes five mph. turn off start up drives fine. im about to burn this thing.
Apr 21, 2013 | 2005 Mazda 6
U0073 u0101
0073 ambient air temperature sensor circuit high input 0101 mass or volume air flow circuit range performance problem it sounds like the mass air flow sensor is dirty check with your G.M. dealer to see if its still in warranty
Sep 04, 2012 | Chevrolet Aveo Cars & Trucks
Error code U0101: Lost Comm with TCM
i do have the same problem and i took the car to 5 differant mechanic an dget no solution the aaamco the petboys the mazda dealer another transmission specialist please let me know if u have any solution
Jan 02, 2010 | 2006 Mazda 3
GPS Logo
76 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
