Question about Boating
Honda 90 putboard 4 stroke 2000 - shift doesn't appear to travel long enough to go into reverse. tried adjusting linkage at control, but now it sort of won't reach f or r
  • 541 Answers
Check gears for broken teeth
Posted on Jul 04, 2010
How do I adjust the shift linkage cables.
Your shifter cables are most likely worn out or stretched out. Adjusting the cables moves the shifter arm a little bit. The turnbuckles for adjusting are inside the center console under the shifter arm. To get to them, you have to take out the center console. One cable controls side to side movement and the other controls front to back, don't adjust the wrong one on accident. 25311622-za4bqvjhdrn3arnyccyp5xaz-3-0.jpg
Dec 07, 2014 | 1989 Honda Prelude
Reverse lights only work in between park n reverse
I have to believe that you are right on with the shift linkage on this. I would make sure that a small part is not missing causing it to not set in position just right.
Jan 11, 2014 | Rancho Rs999190 - 1987-2000 Chevy C3500 1...
The parking light estay in reverse ,when is on parking and dont start the engine
Your shift indicator is out of alignment or your shift linkage is out of adjustment. If you have the shift lever all the way up and are sure it has locked into park try shifting to Neutral and see if you can start it in neutral. If it starts this is a simple adjustment. if it doesn't you will need to replace the neutral safety switch or have the TCM repaired at a transmission shop.
Nov 19, 2011 | 2000 Chevrolet Silverado
Moves forward fine, but creeps when put in reverse. when on incline doesn't wasnt to go backwards at all on incline. Havent tried to fix. the linkage is ok, it has hydrolic fluid no leakage noted any...
Try adjusting the main drive belt from engine to transmission. Sometimes the tension is good enough to go forward, but when shifted into reverse the tension on the belt slackens.
I hope this will give you a direction to look in.
Jun 13, 2011 | Cub Cadet Garden
92 honda accord lx when I put it into d4 and the green light is on everything is ok, then if I pull back on shifter 1/4 inch or less it is still in drive but starts out in 2nd, and if in reverse and pull...
I would check the entire shift linkage for worn grommets/parts. You may find an adjuster at the end of the linkage at the transmission.
(novice mechanic)
Aug 19, 2010 | Honda Accord Cars & Trucks
When i changed the clutch about 9 months ago all was well now when i try to shift. i cant unless the car is off. it is like i cant get the clutch in far enough for it to shift PLEASE help it is a 1985 GMC...
is this system hydraulic actuated? if its mechanical theres an adjustment on linkage.(threaded linkage at left side of trans,should be adjusted to have 1/2 inch free play on clutch pedal at top of its stroke.if its hydraulic check slave cylinder and master cylinder for proper operation.
Oct 10, 2009 | GMC Sierra 1500 Cars & Trucks
50hp force that jumps in an out of gear
I need year model to be precise? But here are the basic tools and troubleshooting steps. TOOL (1) a black marker.(2) a tape measure (3) a second person. TROUBLESHOOTING STEPS(1) the force need water so put it in the lake or install water hose.(2) do not start engine yet. remove engine cover and find shift cable by shifting remote control. once you find were the shift cable connects to the shift linkage. learn which way is forward and reverse. is it push or pull by the cable. remove the cable.(3) now the shift mechanism is removed from the boat controls. this test will require you shifting the shift linkage by hand so stay clear of the flywheel and all moving parts. (4) start engine. at idle speed and you in a safe location near the shift linkage shift engine into forward gear by the shift linkage. be aware how far you need to move the linkage before it shifts into forward. Mark that location with the maker somewhere you can see.(5) shift the linkage back to neutral. mark location were neutral begins. you will fill it click out of the forward gear.(6)now shift into reverse gear marking that location.(7) shift it to neutral making that location as you fill it leave the gear(8) shut off engine turn off water or take it out of lake (9) look at you marks and measure the distance between neutral and forward. the measure the distance between neutral and reverse(9) the second person needs to be in the boat to work the remote control. you need to be at the engine with the tape measure. person #2 needs to make sure remote control is in neutral. you need to measure the remote control cable end so you get a measurment with it in neutral. make a note of the neutral lenght.(10) person #2 shift remote control into forward gear. you measure cable end for distance traveled to go to forward.(11) make the measurement for reverse same way.(12) this is how you find out if you clutch dog is to wore out to stay in gear by the travel of the shift linkage compared to the travel of the shift cable. There are adjustments but they only go so far. that means you will have to sacrifice one gear for the other to make up for the distance of travel.
Sep 05, 2009 | Boating
2000 Mercury Villager: Is there a shift lever adjustment? When placing foot on brake pedal and pulling shift lever rearward it doesn't feel like the transmission is completely disengaging and it is...
You may have a loose shift linkage in the steering column. Remove the upper and lower plastic covers behind the steerong wheel (5 or 6 philips head) and see if you have any loose torx head or allen head screws. Ea
rlier models had this isue.
Also, go to this site for Villager Quest help.
http://autos.groups.yahoo.com/group/villagerquest/
Here's adjustment procedure too
SECTION 307-05: Automatic Transaxle/Transmission External Controls 2000 Villager Workshop Manual
GENERAL PROCEDURES Cable Adjustment —Shift Control
  1. Place the gearshift lever in PARK (P) position.
  1. Raise and support the vehicle. Refer to Section 100-02 .
  1. Remove the splash shield.
  1. Loosen the shift cable nut.
  1. Position the shift linkage in PARK (P) position.
  1. Tighten the shift cable nut.
  1. Move the gearshift lever through the entire shifting range.
  1. Verify that the engine will crank with the gearshift lever in PARK (P) or NEUTRAL (N) position.
  1. Adjust the transmission range (TR) switch as necessary, refer to Section 307-01 .
Item Part Number Description 1 043B13 Driver side air bag module 2 — Steering wheel nut 3 3600 Steering wheel 4 — Radio volume control cover 5 — Air bag sliding contact electrical connector access panel 6 — Cruise control cover 7 14A664 Air bag sliding contact 8 13K359 Multifunction switch 9 — Tilt wheel lever 10 13318 Turn indicator cancel cam 11 — Steering column assembly 12 — Steering column mounting bracket nuts (4 Req'd) 13 3C695 Lower column shroud 14 — Steering column opening cover nuts (3 Req'd) 15 — Steering column lower yoke bolt 16 3N725 Steering column lower yoke 17 — Steering column clamp bolt 18 3C695 Upper column shroud 19 7210 Gearshift lever
May 05, 2009 | 2000 Mercury Villager
Boating Logo
32 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
