Question about U-Line Refrigerator Ice Maker
I have a U-Line model bi-98 ice maker which stopped making ice. I found it with a ice bin full of water and not running one day. I cleaned ti up and shut it down because I didn't need it for a couple of months. I just tried to start it up again to no avail. After turning the water on and pushing the power switch to the on position the compressor and condenser fan do not come on. The ice maker fills with water and the cube ejector mechinism starts turning and the mold heater comes on. It does this for a minute and than starts over again and the compressor never comes on. I assume the compressor is locked out during the ejector cycle. What should I look for to solve the problem?
  • bobgregg29 Jul 04, 2010
    Someone with u-line icemaker experience needs to address this problem for me
    The comments of both experts were very helpful.
    Thanks,
    Charles
  • 11,800 Answers
Look at the thermostat and at the programmer/control board - they are the ones that control the power to the compressor. Check first that the power is transmitted to the compressor, then if it's received. If it's received you can do one more check of the compressor - connect it directly to the mains, if it's good it should start.
Posted on Jul 04, 2010
  • 4 more comments
    Is the compressor normally locked out during the ice eject cycle?
    Why does the fill, heat and eject cycle keep repeating itself?
    Charles
  • Azrael SRL Jul 04, 2010
    The compressor only works when the water is freezed. When the set temperature of the ice has been reached  - between 10F for the fastest ice production to -10F for the slowes - the compressor is shut down. When the temperature has been reached a heating coil is started. This coil runs on a timer, sufficiently long to melt the ice a little at the surface to unlock it from the mold, then it is shut down. Then the extractor is activated to dump the ice. Then a timer activates the water intake to fill the moulds. When the moulds are filled (if the timer is well adjusted it will be perfectly filled, no more no less)  the water is stooped and the compressor started - the compressor will run till the water is frozen solid and has reached the required temperature . From now on the ice maker will run the process till the bucket of ice will be filled, then its weight will press on a switch and stop it. The speed of the ice production can be adjusted by rotating the control button behind the front grille.
    The process repeats itself because either the pressure/weight switch under the bucket isn't triggered or the controller is malfunctioning.
    As you see your problem is as i said - the compressor doesn't receive power. Find out why as i said before.
    Please see my reply to Shastalaker7 and see if you have any further comments.
    Thanks,
    Charles
    Sorry, i can't see it, each one sees only his comments and your replies to the first post. But whatever you decide to do you should check the compressor first.
    Solution #2
    posted on Jul 04, 2010
    shastalaker7
    Rank: Guru Expert
    Rating: 91.32% , 280 votes
    I would look for pressure in the system. It may have shut down on low or high pressure. Look to see if you have a manual reset for the low or high head pressure switch. If it is air cooled, check the coil, condenser coil if it did trip off on high head and clean the back side off. You have power, a safety switch has shut it down the last time it was used and it would be a manual reset.If you have the original manual, it might come in handy to look through. To check for pressure, find the schrader valve for charging and since ice machines are of critical charge, just remove the screw on cap and depress it just enough to see. If nothing comes out at all, push it in completly, and you will know you have leaked all of the freon out. Check these things out and let me know the out come. I will be here if you need me.
    Sincerely, and have a great 4th,
    Shastalaker7
    A/C, Heating, & Refrigeration Contractor PS, Please be kind when rating me, that would be kind of you.
    Jul 04, 2010
    shastalaker7
    Rank: Guru Expert
    Shastalaker7
    My answer to him:
    - I rigged the compressor wiring to make it hot direct from the power cord and it works perfectly. The compressor and fan are grounded thru the thermostat and when I removed the thermostat from the circuit the compressor and fan run okay and cool like it should. What this tells me is that the thermostat is bad and I am now trying to figure out how to remove the ice maker so I can attach the cap tube from a new thermostat I need to buy some where
    By the way the compressor has no charging valve on the suction side, only a crimped copper tube.
    Is there any thing special I need to know about removing the ice maker and replacing the cap tube from the new thermostat?
    Thanks,
    Charles
    I have now removed the thermostat and getting ready to order a new one
  • Azrael SRL Jul 05, 2010
    Just be very careful with the icemaker, the tubes are very brittle so move it slowly.
    President:
  • 1,515 Answers
Shastalaker7
  • 2 more comments
    Thanks,
    Charles
  • Robert Horton
    Robert Horton Jul 05, 2010
    What I would try and do at this point, you know the stat control is faulty. You are runniing the compressor by wiring it to direct power so you know its good, and now you need to add a thermostat to control it. What I would do my self instead of buy a roll of cap tube to cut and fit a piece, is to try putting a Penn a-19 control stat in the are of the evaporator and wire it to cycle the unit off when it reaches harvest temperature, either the type with the bulb, 48" cap on it or just the standard coil type. I would go with the 48" one by Penn controls. The freon is good if it is cooling good, and if it has no service valves on it, oh well. If you ever need to check it, you will have to install a couple of piercing valves to clamp on the suction and liquid lines to check. If you still want to go your way with cap tubing1/8", you can get it at a appliance parts house unless you know a contractor you can get a roll at a a/c refrigeration parts house. They stack all you will need to finish the job. You just need to get to the inlet of the evaporator coil to mount this, may take some time and no real easy way to do it, just take your time and make sure its wired right and mounted right. I wish you the best. Let me know on the outcome.
    Shastalaker7
  • Robert Horton
    Robert Horton Jul 06, 2010
    Hi, BobGregg, can you rate me as far as being any help to you on this unit. It would be very kind of you to do this for me. I wish you the best of luck, and all you need is to place the stat in the best location and a easy place.
    Sincerely,
    Shastalaker7 A/C, Heating, & Refrigeration Contractor.
  • Robert Horton
    Robert Horton Jul 12, 2010
    Hi, please do not forget to rate us on our help to you. Thank you very much, and I hope I was of help to you on this machine,
    Shastalaker7
I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
CM3 Operational Sequence.
From Off, push and release the freeze button.
1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
2. Compressor starts when sump is full.Air cooled fan motor starts too.
3. water pump stops early in freeze cycle for 30 seconds.
4. Sump refills after pump starts.
5. In low ambient condition,fan motor may begin to cycle on and off.
6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
7. Fan may shut off before the end of freeze.
8. Harvest begins. Hot gas valve opens,pump stops.
9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
10. Harvest continues for preset first cycle harvest time.
11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
Oct 28, 2014 | Kitchen Appliances - Others
My BI98 u-line ice machine won't stop making ice even with bin arm up.
I would suspect the switch controlled by the tray full sensing arm/bail. That's kind of like the main power switch for the ice maker. You can remove the outer cover from the ice maker with the power unplugged! Then look at the mechanical operation of that lever as it relates to the switch. The lever should cause the switch to open and shut off the timer motor. Some times you can buy the timer separately otherwise you replace the whole icemaker. Don't forget to remove power and turn off the water before you remove the old icemaker.
Oct 15, 2014 | U-Line BI-98
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Does dump valve shut off after making ice
is your bin line and dump line tied together if so it could be just ice melting. If not can you here water filling up constantly while machine is off? if so is it running over sump tray into ice bin. if dump valve was stuck open then machine will not make ice.
Jun 25, 2013 | Scotsman Kitchen Appliances - Others
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
My u line under counter ice maker (bin, not clear ice) will take forever to make ice. Once it starts to make ice and drop it in the bin, several hours later it will stop making ice and the made ice will...
Can you tell me the model? If its a bi series then it should make ice every 45 min. temps should be 10-15 degrees in bucket. If its a combo then it could take 24 hours to make 1/2 of the bucket.Should be the same temp in your bucket.Make sure you dont have heavy frost in the freezer, Make sure the condenser fan is running and clean.If the temperature in freezer is alot warmer than this and everythng is running then it could be a leak in the system. If its colder than that then set the thermostat to a warmer temperature
Aug 06, 2009 | U-Line Icemaker
Ice maker stopped working
If you manually advance the ice and when the ejector blade reaches 10 oclock that when it calls for water. You should hear the valve come on. If not it could be a bad water valve. Part#2552A or you might want to doublecheck to see if your getting voltage there when the blade reaches 10 oclock. If no voltage then the water switch is bad.
Jul 19, 2009 | U-Line Icemaker
Uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Jul 04, 2009 | U-Line Icemaker
BI98 U-Line ice maker freezing but not making ice
The cyle is stuck in the midway section. Unpluh the water supply to ice maker anf see if it will return to the fitst stage, If not we will need to look into the ice maker to see if one of the contacts is stuck. Is this a new ice maker and desighned for your refrigeratorr? Sea Breeze
May 27, 2009 | U-Line Icemaker
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
U-Line Refrigerator Ice Maker Logo
109 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
