Question about Compaq Presario 5000 PC Desktop
My computers audio box is not working - Compaq Presario 5000 PC Desktop
  • 487 Answers
Hi, you ned to check if this is installed corrctly, go to control panel, access divice manager. If there is a problem there will be a yellow ? sign. Identify your device and download the appropriate driver.
Posted on Jul 05, 2010
Cubase studio 5 has deactivated the VST system links due to too many internal errors
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).
You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.
You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.
Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
Oct 08, 2013 | Lexicon Omega Desktop Computer Recording...
Vst system link errors
May 23, 2012 | Lexicon Omega Desktop Computer Recording...
After unplugging my computer for a week, the sound on my CLT 190 LX computer monitor didn't work, even though I tried several sound sources from online as well as MP3s on my computer. The headphone...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
May 10, 2011 | Computers & Internet
My audio jack is not working .................why .....................
Open up your computer the speakers plug/outlet is usually at the back of the computer
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
also if you mean that your microphone wont work from the audio jack
hope this helps
hope this helps
Mar 25, 2011 | Acer (54.AA806.001) Sound Card
Sound isn't working, and there is no audio device to select from either. It is my friends computer (the email given is also hers). It's an HP computer, her son tried to get the sound to work and deleted...
Hi. It sounds like what your son did caused the audio service to stop.
Here's how to fix that, if it is in fact that.
First, click on the start button
Next, click on run, and type services.msc
this will open the services box
Go almost completely to the end of the list, and you will see windows audio
click on it one time, and if the audio service is actually running, then it will give you the options of stop, and restart service
If it doesn't say that it is running, then the only chioce it will give you is start .
click start, or restart, whichever one is offered.
next, double click on windows audio and a property box will pop up.
On the drop down menu in the middle, it will give three choices, automatic, manual, and disable
set it to auto
Next click on the recovery tab, and set all three drop downs to restart service
then click apply.
then close property box, and then close services box
reboot computer, and if that was the problem, you should now have sound!!
Jan 29, 2011 | Altec Lansing ACS 22 Computer Speakers
MY COMPUTER HAS NO AUDIO DEVICE I SEARCHED ON THE INTERNET BUT NOTHING WORK OUT PLS HELP ME TO SOLVE THIS PROBLEM
mcdevito75 here, Most Computers (Desktop) have built in Audio devices but you"ll need outside speakers, and you have to mke sure the audio is on in your computer. ----- Try this, in your computer click on start, then Control Panel, then on audio speakers devices, then un--check the MUTE box and Check the Place icon in the task bar box. Then hook up speakers to your computer, speakers available at Staples, Radipo shack etc.
Jul 02, 2010 | ASUS P5P800-MX Motherboard
Audio card problem
remove audio card, if computer work shotdown and insert back audio card if machine down, remove and replace that audio card with new one.
Apr 15, 2010 | Intel Celeron 2.4Ghz Socket 478 CPU (...
Sound from my tv card, skydude doesnt work on my hp laptop, vista home premium
You haven't mention about the connections you have with the SKYDUDE TV box. TV boxes usually have AV (audio and video) connections i.e., two seperate connections for audio and video signals. If you are using a set top box to connect to the tv box you can connect the "video out" of the set top box to the "video in" of the tv box using a cable. and "audio out" of the set top box to the "audio in" of the TV box using another cable. Some TV boxes don't have the "audio in" option. In that case you have to connect the "audio out" from the set top box directly to the "audio in" of the computer. This pin you can find just near the "speaker" and "mic" connections.
If you have an S-Video pin in your TV box, you can use an adopter wire to connect two "audio in" and one "video in" connections to the same pin. And you have to select S-Video option in the software installed.
If you have "RF in" option in your TV box, you can use use AV to RF converter to connect your set top box to the TV box.
Thank you,
Apr 25, 2009 | Computers & Internet
No audio/cable box to computer monitor using hdmi/dvi
Hi lauriesbc
if you take the audio feed from your cable box via the line out sockets then plug into line in on your sound card you shud be able to get audio.....
hope this helps
Feb 16, 2009 | Dell Dimension 3100 PC Desktop
Compaq Presario 5000 PC Desktop Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
