Question about Apevia 700-Watt Power Supply
Apevia Aqua problem
I installed this PSU and the switch will not stay in the off position. hWhen on, the computer powers up for 2 seconds then cuts off, this continues until disconnected.
Can anyone advise?
Thanks,
Keith
    Brigadier General:
  • 10,406 Answers
Reinstall the old power-supply (or borrow another power-supply) and try it. If the problem vanishes, then the newly-purchased power-supply is faulty, and should be replaced, under warranty.
Posted on Jul 04, 2010
Lightning storm & power went out for about two seconds. PC plugged into surge protector but would not go back on. Found that surge protector blew and was no good. Got another and plugged all back in...
Your reasoning about the switch mode power supply being damaged is probably right.
Bear in mind that this power supply may not be the only thing that may be damaged in your computer.
You won't know for sure until you borrow a power supply and install it into your computer to see if it will work again.
Jun 18, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
Good afternoon. I purchased the apevia, WIN-500xspx and cannot get it to power on. I have tried it both in the computer and out of the computer and it will not give any indication of powering on at...
Here are some web sites that will help you install your power supply correctly. Power supplies provide power to the motherboard and other components of a computer and need to be hooked up correctly to the components in order to give power.
http://www.build-your-own-computer-tips.com/install-a-power-supply.html
http://compreviews.about.com/od/tutorials/ss/DIYPSU.htm
May 10, 2011 | Apevia WIN-500XSPX 500-Watt Power Supply
When I start up my computer, nothing happens. The hard drive doesn?t spin, the fans don?t work, nor do I get any display. I?ve checked the power strip and know that power is getting to the computer, but...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 06, 2010 | Computers & Internet
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Working fine until psu packed in, replaced psu, begins power up
The PSU dying may have destroyed the motherboard also. Try removing all interface cards and disconnecting all drives to make sure.
Nov 11, 2008 | Foxconn WinFast K7S741MG Motherboard for...
My computer lights
hello,
i assume you know how to open your pc...
Solution (1)
1. make sure your computer is not plugged in
2. open the side panel
3. remove the memory card
4. plug in you computer
5. switch on your pc. you should hear a beep. this is to check whether your pc is still working.
6. unplug pc
7. re-install the memory card. make sure that it is firmly attached to the memory slot.
8. switch on again. this should do it.
else
Solution (2)
Try replacing your power supply unit (PSU). faulty PSU may not be able to supply enough power to your motherboard or other peripherals which is attached to your PC.
hope this post can help you :)
Aug 05, 2008 | Computers & Internet
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
Comp not firing up
Something may be shorting out the board. Try taking the motherboard out and turning it on without the case. Just put the motherboard and power supply on a non-static surface. A box works well. Then use a flathead screw driver to temporary "jump" the 2 power switch pins for the front panel connection (as you wont be turning it on while inside the case).
If that doesnt work, then replace power supply. You could also take one out of another working computer just to test.
Jun 18, 2008 | EliteGroup K7VMM Motherboard
P35 Neo2 fails to power up
try to clear cmos here is the way if u dont know:
get to the jumper next to the mainboard try to change its position for 3 seconds then put it back to its normal position.
start the computer , enter setup and save defaults.
May 26, 2008 | MSI Computers & Internet
Apevia  700-Watt Power Supply Logo
65 people viewed this question
Top Apevia Computers & Internet Experts
Paul Carew
Mohammed Ebrahim M
Mohammed Ebrahim M
Bill Boyd
Are you an Apevia Computer and Internet Expert? Answer questions, earn points and help others
