Question about HTC Hero Smartphone
My power button doesnt work anymore
Once my phone dies or turns off i cant get it to turn back on because my power button doesnt work anymore..is there a way i can turn it on without the power button..taking the battery out and puttin it back in wont turn it on either
  • 16 Answers
Mine turns on when I plug the charger into it. Have you tried that?
Posted on Jul 04, 2010
My Iphone4 wont turn on.(the power button is jammed been so for awhile).it always been in a otter box,almost 2 years old. and it was in my pocket and was working fine 1 minute pulled it out the next i
try putting it back on the charger & see if it turns on a friend of mine had a jammed lock button & when her phone died thats the only way she could turn it on. if it doesnt than theres most likely a battery problem. Also go in a very dark room & see if it works the backlight could be out on it
Feb 18, 2014 | Cell Phones
Htc amaze power button is broken. Cant turn it back on
If it is just the button ie the plastic bit then under it shoudl be a tiny micro-switch press it with a blunt instrument.
Jan 28, 2014 | HTC Cell Phones
Power button wont turn
Soft reset by removing the battery, wait 20 seconds and reinsert.
If this does not solve the problem...
1. Remove the battery, wait for a few seconds, then reinsert the battery to turn off your Merge.
2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
3. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
If none of this works, get a new phone, hopefully you have the insurance.
Dec 17, 2013 | HTC Cell Phones
My iphone lock button doesnt work and it just died on me, not battery dead, just off and i cant find a way to turn it back on
If the phone is charged, you should be able to turn the phone on by pressing the home (circle) button.
Aug 19, 2011 | Apple iPhone Smartphone
I connect the charger of my htc hero. at first it was charging. after an hour i noticed that it stopped from charging. when i turned on my phone it didn,t open.
Open the back cover , take the battery out . Press and hold the power button without the battery . Put the battery back in . Try to power it on .
If that doesnt work try below steps , ( note : you will loose your data )
Power the device OFF. Press and hold the HOME and Back Arrow buttons. While holding these buttons, press the End Call button once. Release the Home and Back Arrow buttons and press the Trackball to execute the Hard Reset. The device will reboot once the process is complete.
Thumps for my solution if it works .
Aug 15, 2011 | HTC Hero Smartphone
My mix max doesnt turn on. it was working and all of a sudden it said "connect to usb". i did then it turned off and it doesnt turn on anymore i tried to charge it but it still doesnt work. HELP!!! please.
If this doesn't help, the MixMax must be opened up. By CAREFULLY prying the corners loose, you can remove the back. You will break several of the smaller retainer clips during this, but it's OK. The main retainers will hold the unit together just fine once completed. Once opened, unplug the battery. NOTE THE ORIENTATION of the red and black wires. Use any 5V 500ma or less power supply and connect to the battery. Charge it for at least 30 seconds. return the battery to the unit, and reassemble. DO NOT TURN IT ON. Plug the USB cord in and let it charge completely.
The MixMax will disable the power if there is an unexpected power interruption, then the battery will run completely dead. Once dead, it cannot detect the USB when connected.
Jul 30, 2010 | Disney Mix Max Digital Media Player
My samsung R410 end button doesnt work
I have the same exact problem. I had to get a new phone. I am trying to sync with it to get my numbers off but no luck so far
Aug 13, 2009 | Samsung SGH-D900 Cellular Phone
Restore still wont let me in
If you know how to put the phone in DFU mode your itunes will see it as in recovery mode and allow it to be restored.
If your planning on unlocking the phone for use without an iphone account, It's super important to restore the phone with firmware from 2.2 5G77 back. Don't restore to 2.2.1
Get the firmware here
For putting in DFU Mode
Plug the usb into the iphone and not into the computer.
1) turn your phone all the was off. (with the red slider)
2) Hold the home button for 5 second and then press and hold the power button for 7 seconds (Holding Both buttons down)
3)let go of the power button and keep holding the home button for an additional 27 second. your screen may go blank. don;t worry
now plug your usb into the computer with iTunes open.
iF it mounts in itunes it will say it's in recovery mode. press the shift key and press restore with you mouse choose the iphone firmware you downloaded from the link and restore.
I believe this solution will help, good luck!
Mar 01, 2009 | Apple iPhone Smartphone
Samsung d840 can i turn it on without the on button?
jd014e9445 - the power button needs to be resolder back on or replace....so take it to a mobile service center to have it rectify.
May 08, 2008 | Samsung SGH-d807 Cellular Phone
HTC Hero Smartphone Logo
495 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
