Question about Canopus ADVC-110 A/D Converter (77010150105) Video Capture
PAL Problem and ADVC110
I have a camera that outputs PAL-B format. I can read the camera with my PC using a Plextor TV-402U withouth any issues other than some frame rate issues that I am hopping to solve by using the ADVC110. However, the issue I have with the ADVC110 is that the PAL is, for lack of a bettery phrase, jittery. I see the vertical lines "jitter, and repeat. I do that have the problem with the Plextor and the Plextor is set to PAL-B format. I also have tired teh ADVC110 with the same camera in NTSC mode and it works fine, it is just the camera does not do as well in NTSC mode vs. PAL. Any ideas why this may be happening with this video capture box. I have seen the issue with Windows Movice Maker, ULead Video Stuideo, and even the bundled Neo software from Canopus.
Thanks,
John
    Scholar:
  • 119 Answers
It's difficult to tell what's really going on by looking at the PC monitor. You should generate a DV file and play it back through the ADVC to a TV and see.
The issue is interlacing. Since the two fields of interlaced video are originated at different points in time, when you play both fields on a non-interlaced display like a PC monitor, you see the two combined and they don't match up. So you get half of a ball before the line, and half of the ball after the line and it looks funny.
Posted on Aug 11, 2008
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
How do i convert a ntsc file to a pal file??
Here's a complete How-to article on PAL (phase alternating line) to NTSC (obsolete analog TV) conversion:
http://www.deskshare.com/resources/articles/dmc_convertbetween_PAL_NTSC.aspx
What's required is Digital Media Converter software - since images on a DVD are stored
in MPEG2 format.
Here's the (free) MPEG2 decoder you'll need:
http://www.deskshare.com/download/mpeg2decoder.exe
With thanks to deskshare.com
Feb 13, 2011 | Microsoft Office Professional 2007 Full...
Does my comp Video Card supports digital signal output through VGA function? If not, what kind of cable i have to use to connect it to TV Toshiba(flat ckreen, digital)? I'v tried many cables... just...
no vga is just analoge use a svideo cable and set it up as pal if your tv is a pal or ntsc if ur tv is ntsc the tv format is not right ntsc is us pal is japan it can be found the ati cfg utility
Jan 18, 2011 | Gateway MT6840 Notebook
PS2 disk issues
ps2 PAL format cannot read NTSC\UC.NTSC\UC is for ps2 that have the logo NTSC\UC in the ps2.
Mar 05, 2010 | Sony PlayStation 2 (PS2) Console
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Canopus ADVC110
Yes you can. I have that very same setup using a surveilance cam as my webcam =)
Yawcam is a pretty good allround webcam application with lots of features, I recommend it!
Sep 29, 2008 | Canopus ADVC-110 (77010150100) Video...
Set up video output
Pal output will only work when it is plugged into a pal tv. The only way you can restore is to use the remote to put the settings back to ntsc without using the display. That should work. If you don't have a pal tv you should never change devices to run on it, because it can damage your tv set. The scanning lines are very different between the two systems.
Aug 14, 2008 | Cyberhome CH-DVD 300 DVD Player
ADVC110 - not recognised by computer
If you're using the AC adapter, try it without (using a 6-pin to 6-pin Firewire cable) the AC adapter.
Otherwise try a different Firewire cable.
Jun 23, 2008 | Canopus ADVC-110 A/D Converter...
Play NTSC(U/C) PS2 disc on console which outputs PAL signal
Hi hari,
A mod-chip will resolve this issue on your PS2.
Apr 28, 2008 | Sony PlayStation 2 (PS2) Console
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Open Questions:
Canopus ADVC-110 A/D Converter (77010150105) Video Capture Logo
133 people viewed this question
Top Canopus Televison & Video Experts
Yoav Shilon
Yoav Shilon
Alun Cox
Troy Staley
Troy Staley
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
