Question about Hotpoint Ultima WF860 Front Load Washer
Unable to open door
Wash cycle finished and tried to open door but handle is loose and floppy
    President:
  • 1,382 Answers
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Posted on Jul 04, 2010
Door stay locked after finished washing hotpoint w/machine ref 9526
See if you notice any water still inside the washing machine, if so run another spin cycle to try and remove it as it will not open if there is still water inside.
If you don't see any water inside, try unplugging it and letting it cool off, the lock should release after this
Jul 03, 2016 | Hotpoint Washing Machines
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Door light flashing and unable to use the washer
If you have ascertained that the door is closed properly, and that the door handle does not feel floppy or weak, then chances are it could be faulty module, as this supplies power to the door lock.
Feb 04, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Indesit wd 125. Wash cycle had finished, door lock was off but
Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
Jan 19, 2010 | Washing Machines
Door will not open on creda ied12, finished cycle looks like the handle is loose
Needs a new door handle kit which is the easy part.
the hardest part is getting the door unlocked, play with the handle to unlock it, or take the top off and try unclip the catch from the interlock .
You may have to break the door plastic, don't break the interlock though and buy a new door
Sep 19, 2009 | Washing Machines
Can't open the kick plate of my samsung j845 washing machine
Happened to me too today. As I was pulling the handle, a piece inside snapped. The handle felt loose, as though it wasn't pulling the catch. To get the door open, I used a screwdriver. I pulled the handle as far out as I could, so that I could get the screwdriver in. The dark black metal part has to be levered away from the washing machine - in the direction the door would open. That will release the catch and then the door will open.
After the door is open, the challenge is to remove the handle. You'll need to undo all 10 (or so - from memory) of the little screws, so that the inner part of the door comes off. Be careful as you get to the last one - things will fall away. The handle and the small broken tab just fell out for me. Once the handle is out, you can put the door back together again. I use a small hex key to help open (and close) the door. With no handle, the catch springs a bit too far over for the door to close, so you'll need something (e.g. 1/8" hex key) to hold it over a little. So now, I can use the washing machine while I try to find a new part.
Apr 11, 2009 | Washing Machines
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Door of indesit washing machine no opening model no WM12X
First thing if this unit has an electric lock you probably open the door at the wrong time and threw it out of sync. First try to do another load from the beginning cycle and let it finish. If this don't work unplug your machine and then try. I hope this helps you.
Nov 23, 2008 | Indesit W 123 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
421 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
