Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side refrigerator side not cooling but freezer side works fine.
catriver
  • 878 Answers
SOURCE: GE side by Side Fridge
froggy, First check the back panel of the freezer section and see if you have a big frost build up. If so, you probably have a defrost problem, heaters more than likely. If there is no frost build-up check to see if the fan in the freezer (evaporator fan) is running. If that's ok, next would be the automatic damper. Have someone unplug the refer. Open the refer door and listen for the damper door to open when someone plugs the refer back in. If thats operational, next would be the thermistors, you would have to ohm them out to see if they are in range. Seldom is this the problem. Check these things out and get back on what you find. Catriver..post back.
Posted on Apr 04, 2007
Maanita
  • 1142 Answers
SOURCE: refrigerator not cooling
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
SOURCE: maytag refrigerator side-by-side model MSD2756GE
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Posted on Sep 05, 2008
aasc
  • 1606 Answers
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
Posted on Jul 21, 2009
  • 24 Answers
SOURCE: Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Posted on Jul 28, 2009
I have a GSS22IBMA GE side buy side. The fridge side works fine but the freezer will not freeze. Also it is hot around the the door frame of the freezer sometime quite hot.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | GE Refrigerators
I have a GE profile side by side and the freezer works fine but there is warm air that is blowing into the fridge part.
heatman101
Sep 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
M#gss201embww the freezer side is working fine but the fridge side will not remain cold continously
heatman101
Jul 17, 2011 | GE Profile PSS26NGS Side by Side...
My refrigerator isn't cooling. The freezer however is working fine
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 12, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Refrigerator not cooling, freezer seems to work fine.
heatman101
Dec 21, 2010 | GE GSS20IEP Side by Side Refrigerator
Gss221frfww. freezer working fine fridge side at 46 degrees... set at max! please help!
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 27, 2010 | GE GSS20IBPWW / GSS20IBPCC Side by Side...
The freezer works fine, refrigerator section not cooling it is 6 yrs. old, should it need a refrigerant(freon) charge ?
heatman101
Nov 09, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Frig wont cool but freezer works fine
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 11, 2010 | GE GSH22KGPBB / GSH22KGPCC / GSH22KGPWW...
Freezer working fridge not
heatman101
5gf
Jul 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
547 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
