Question about Garden
RY26500 Gas Trimmer. I took apart the throttle case,( I did this because the start lever would not stay in start). Upon taking the throttle case apart I found two springs in case. Item 32 on parts list and other spring. This other spring doesn't appear on parts drawing(view A). Wonder what to do with this spring. Also how would you put item 32 back in case, What steps do I follow?
  • Waynew05 Jul 04, 2010
    yes thanks for the help
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Tip
    Ryobi RY26500 Gas Trimmer Parts Manual Download
    Download Ryobi RY26500 Gas Trimmer Parts Manual
    Would you like a digital, searchable, pdf version of the Ryobi RY26500 Gas Trimmer Parts Manual?
    Follow this link (& click FREE) to download a pdf version of the Ryobi RY26500 Gas Trimmer Parts Manual.
    I hope that helps.
    ___________________________________________
    on Jul 03, 2010 | Garden
    Weed eater head spins on its own, no power.
    check the compression on your weedeater low compression will cause this
    Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
    PROPER WAY TO START TRIMMER.
    Pump the primer bulb on the carburetor at least 7 times....set choke lever ( the yellow lever on the air cleaner) to the down start position....pull start handle till it fires....let machine run for about 30 to 45 seconds before you open the throttle to give it a chance to warm up....that's it !!! ;-D
    Jul 05, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    I have a poulan pro trimmer, it wont stay running
    First of all, YES. boggs is a word in my dictionary. Remove the muffler and carefully take it apart. Pay close attention as to how it comes apart because it is vary important it goes back the same way. you will probable find that it is clogged. If it is then remove the debree. If it isn't then you will have to adjust the fuel mixture screw. First start the trimmer, then let it run for a few minutes to warm up, then gently turn the screw a little bit at a time counter clockwise first, squeezing the throttle inbetween adjustments . If it starts to take off then fine tune it untile your happy. If it boggs worse then turn it clockwise.
    But first check the muffler.
    Good luck
    Aug 05, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
    Troy Bilt trimmer model # TB575SS no high throttle
    Dont replace the carb! The gaskets are what wear out on walbro carbs and the like. Specificaly the fuel inlet membrane which is under the removable plate opposet of the throttle plate.It is a black gasket with a small metal button in the middle. This regulates the fuel supply. If if is still flexable then it is good. Usually they become crisp after sitting for a couple years. Start with a gasket set( 5 to 10 bucks) Then try adjusting your fuel and air mix needles if need be.
    Jun 08, 2009 | Troy Bilt Tb70ss Gas Trimmer
    Garden Logo
    52 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
