Question about Sony Playstation 3 (PS3) Console
Can't sign in to network. It says go to settings. Then it say an attempt to obtain ip address timed out. I know my router is working bc I'm on my ipad now.
  • Sony Master
  • 4,806 Answers
You will have to wipe the network settings and in re-input your SSID and Password again to the PS3.
Regards.
Posted on Jul 04, 2010
I have an Internet Connectivity problem which I believe was caused by resetting our D-Link WBR-2310 router. We have a strange, perhaps illogical network setup in our office. Although it was set up before...
It appears you are not using the wireless connections on both the routers and the reason for using Router B was that there were insufficient LAN ports on Router A to connect to the two workstations that are connected to Router B.
To simplify your network, I suggest you replace Router B with a network hub or ethernet switch and connect the two workstations to this network hub/switch, then configure these two workstation to Obtain an IP address automatically. Router A will then issue IP address to these workstations via the network hub/switch.
Jul 09, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Jul 09, 2011 | Computers & Internet
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
To specify DNS server address settings, do one of the following:
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
My ps3 can't get an IP address
Playstation 3 won obtain the IP address Solved Closed
Try that forum. A few solutions that should help you out. If you have a media server on the network that could cause minor issues sometimes too.
Aug 14, 2017 | Sony Playstation 3 (PS3) Console
2 Pc's with same IP
AT either desktop or laptop:
[Start]
[Run]
[cmd]
A dark "DOS" windows will appear
At the prompt, type: ipconfig
press [ENTER]
Note the "IP Address" (probably 192.168.1.2)
type: ipconfig /renew
press [ENTER]
Note the IP Address
If it has changed, then you are ok. Type: exit and press [ENTER]
If it did not change, then try this on the other computer.
If that didn't change either, the go to the Control Panel
[Network Settings]
Find the wireless or wired network adapter and Right-Click
Choose "Prpoerties"
In the Properties window, double-click "IP Address"
See the IP Address assigned? change the last digit by one number.
Example: if the IP Address is 192.168.1.2 then change to 192.168.1.3
[OK] [OK][OK]
It should work now...
Let us know!
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
I cant connect my wireless laptop tp my comp.
Let me know the settings of your Router if needed IP address?
Yes - add your IP address into Network Connection.
No - obtained the setting in your Network Connection.
How to Add or Obtained the setting s of your IP address:
- goto Control Panel
- Double Click Network Connection
- Rigth Click then Properties the Local Area Connection
- Select Internet Protocol (TCP/IP) and select Properties
- Under General Tab they have choices to add or obtained settings.
Sep 20, 2008 | Linksys Wireless-G WRT54G Router
Keep geeting an error message another IP address has been detected. I have a wireless router & laptop, and a desktop whcih the the main computer.
If you have Vista,
  1. Go to START > CONTROL PANEL
  2. Under Network and Internet, click VIEW NETWORK STAUTS AND TASKS
  3. On the side panel, click MANAGE NETWORK CONNECTIONS
  4. Right click your Wireless network, and click PROPERTIES
  5. Single-Click Internet Protocol Version 4 (TCP/IPv4)
  6. Click Properties
  7. Write down all the infromation in case you need to type it in again later.
  8. Click "Obtain an IP address automatically" and "Obtain DNS server address automatically"
Sorry, but I cannot help with XP at the moment.
Mar 06, 2008 | Computers & Internet
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Laptop connects, but main computer doesn't....
if you have the router set to enable dhcp which gives your network cards an ip address automatically, then check that the network card of the main pc is set to obtain ip addresss automatically, this is in network connections, right click on network connection icon, properties and on the TCP/IP line click properties and check that 'obtain ip address automatically is ticked, apply and ok. Igf you have tried to repair the connection using wizard, then your settings will have been changed, thats possibly the problem. Also go into the routers settings and see if the main pc is listed under dhcp clients and that an ip address is given.
May 16, 2007 | Belkin (F5D5231-4) Router
Sony Playstation 3 (PS3) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
