Question about Mitsubishi WD62628 62" Projection HDTV
Trying to access the device menu on our WD 62628 causes the system to reset itself. Help!!
  • 58 Answers
Reset the tv by pressing menu and 2470 then enter. If this doesn not fix then you have either a bad e2p or dm.
Posted on Jul 06, 2010
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
Mitsubishi WD-62628 power shuts off!
You most likely have some faulty capacitors on the power module. You can easily identify a bust capacitor. They will have swollen tops. Here is a sample pic:
Check the specifications of the faulty capacitors, and getthe replacements from your local electronics shop. If you are comfortable withthis, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out thedefunct capacitors. Once that is done, solder in the new capacitors carefully. Ifare unsure how to do this, try to get a friend who knows this kinda stuff to doit for you, or get a qualified technician.
Warning: If you do not have a background inelectronics repair, or are inexperienced, get a qualified technician to do itfor you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
If you want to go in for a long term solution, youcan easily replace the whole power board. You can get spare from HERE.
They also offer FREE online technical advice as you do the DIY..
Hope that helps!
Oct 03, 2008 | Televison & Video
Mitsubishi wd-62628 flashing error code 41 (short) now what?
Short detected in standby power supplies. on pwr PCB check the following:
1)12VS @ connector PD pin 14: possible cause;IC9A23 circuit
Zener D9A41
2)5V @ connector PC pin 8: possible cause;IC9A21 circuit
Q9A12 circuit
zener D9A47
3)4.5V @connector PD pin 16 possible cause: F9E10
F9E11
Dec 28, 2014 | Mitsubishi Televison & Video
Does the wd62628 have a factory reset button?
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Sep 09, 2014 | Mitsubishi 915p026010 Wd-62627/Wd-62628...
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
I have a wd 52825 and accidentally hit the system reset button with a stiff brush...now the green light won't stop blinking and won't power up...what are my options?
I found this on the web .... might help ... dont know but it might be worth a try....also removeing the bulb and checxk it
Front Buttons Do Not Work Cause 1
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds.
Locks up when Device Button Pressed Cause 1
1. Initialize settings by pressing "menu, 2, 4, 7, 0, enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the netcommand and tuner settings.
2. Initial and reset does not resolve suspect the DM PCB part # 934C116001 .
Oct 31, 2010 | Mitsubishi WD-52825 52" Rear Projection...
No picture after changing lamp, tv will not power up.
Try bringing up the menu. If you can't I'd suspect the fmt board if you can suspect the dm module.
Bill
Nov 24, 2008 | Mitsubishi WD62628 62" Projection HDTV
Wd 62628 tv
After I reset the system, the Audio menu gave me access to the TV speakers that had been turned off. I turned them on and had to wire audio cabes from my sat box to the component audio in on the TV.
Sep 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
hold the MENU and DEVICE buttons when turning on the TV and get error code
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD62628 62" Projection HDTV Logo
417 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
