Question about Meade ETX-90EC (325 x 90mm) Telescope
Etx90 geartrain broke
I OWN A ETX 90 THE GEAR DRIVE HAS ONE COG WITH STRIPPED TEETH THE REST OF IT IS GOOD. IS THERE A SOURCE FOR THESE COGS OR GEAR BOXES AS i AM CONFIDENT i COULD GET THE SCOPE REPAIRED WITHOUT THE HUGELY EXPENSIVE OUTLAY OF SENDING THE WHOLE THING BACK TO MEADE FOR REPAIR.
  • Anonymous Mar 13, 2014
    plastic cogs in alt axis have lost teeth
    stripped cogs meade rb70
  • 3,186 Answers
Only Meade has parts. Usually they want you to send the scope back to them for repairs. However you can contact their customer service department and ask if they will sell you just the part:
Here:
http://www.meade.com/support/index.html
Posted on Jul 06, 2010
Is there a gear kit for the Fellowes MS-450CS Micro Shredder?
Hello Jay
I have the same problem. I found a place that sells nylon gears. They are not to good in responding back though.
This is the email address and the lady's name is Delores
sdp-sisupport@sdp-si.com
The cog below is shattered on the spindle and the bottom one, the skew spindle has chewed a hole in the cog in one place. I would like them all replaced with bronze.
Here are all the Cogs, tantalisingly close. Tell her I sent you!
http://www.sdp-si.com/eStore/CoverPg/Gears.htm
SDP SI ON LINE eStore offers Spur Gears Helical Gears Miter Gears Worm...
Dec 19, 2011 | Fellowes Manufacturing Powershred ...
I have a 2004 GSF600S, when I put it on centerstand and spin the back wheel slowly. There is some regular clicking sound from the transmission / gear box section. You can actually feel the click vibration...
check the tooth profile on the drive cog and the cog on the wheel
if they are more spiky that properly formed as in a new cog
then what is happening is that the pitch of the cog has altered from wear and the pitch of the chain ( distance between link pin centers ) is no longer compatible so the chain tends to ride up on the teeth and then clicks back in place
the fix is a new chain and cogs or if the teeth are good , just a new chain
Oct 14, 2017 | 2004 Suzuki GSF 600 S Bandit
I have a Meade ETX-90/ec telescope, the verticle lock knob will not thighten. It appears to be stripped. how can I fix it? Where can I get a parts list? Thank you
The bolt is stripped away from the plastic knob-- TAKE THE vertical lock knob off and inspect the bolt head-- you can use a STRONG glue to fix it -- epoxy or something similar.
Aug 29, 2011 | Meade ETX-90EC (325 x 90mm) Telescope
Cannot get rear derailer to work properly 24 inch girls evolution
Don't start messing with the derailleur yet! Make sure your shifting trouble isn't due to something else, such as a warped, dirty, or stretched chain, gummed-up pulleys, crud in the cable housing, trapped cable, or a bent derailleur hanger
Clean the chain and the rear derailleur pulleys. Pull the chain away from each pulley, and turn the pulley to make sure it can move freely. A pulley that offers resistance to turning must be replaced.
Now check the cable to be sure it slides freely. Mud and grit within the cable housing, or on a cable-guide, can keep the derailleur from moving a "full gear" during downshifts. If the cable doesn't slide freely in the housing, you may be able to clean or lube it to restore smooth shifting.
Let the high-gear limit screw. In your highest gear on the shifter, and with the chain on the smallest cog, position the derailleur so the upper pulley exactly matches the teeth of the small cog. Run the chain a bit with the front derailleur in the large ring, adjusting the limit screw until the pulley and the cog seem to match perfectly.
Setting the high-gear (small cog) limiting screw.
Once you're sure the derailleur matches the cog, move it just a whisker (1/8 to 1/4 turn) towards the other cogs. (You may need to readjust a bit if you get chain-skip.)
Closeup of setting the limiting screw.
Now adjust the low-gear limit screw. Shift into the lowest gear (largest cog). If it won't go, loosen the limit screw. With the chain on the largest cog (and the front derailleur in the small chainring), adjust the derailleur so the upper pulley exactly matches the teeth of the large cog.Once it's perfect, turn the limit screw so it moves the derailleur a tiny amount towards the other cogs (1/8 to 1/4 turn usually works).
Setting the low-gear (largest cog) limiting screw.
Now shift to the highest gear (smallest cog). Push the shift lever to downshift one gear (go from the smallest cog to the next-smallest). If it doesn't shift, tighten the cable with the barrel adjuster, 1/2 turn counter-clockwise. Backshift and try again. Continue tightening until it shifts. If it overshifts, going from the smallest cog to the third-smallest, loosen the cable by turning 1/2 turn clockwise. Backshift and repeat until it shifts exactly from the small to the next-smallest cog.
Fine adjustment of tension in the derailleur cable.
Now go to the second-smallest ring. Tighten or loosen the cable slightly, until the outer side plates of the chain are just clearing the third-smallest cog. Shift up and down, fine-tuning until you're satisfied.
Checking the position of the chain on the cogs.
Mar 04, 2011 | Pacific International Pacific Evolution 24...
I replaced a broken chain now my bike wants to skip like the chai
Over tim and use, the chain and the rear cogs stretch and shape to form. Replacing the chain usually means replacing the rear cog cassette. If the rear cogs are expensive, then replace the chain more often before it breaks and then you don't have to replace the rear cog cassette
May 24, 2009 | Bell Sports BICYCLE CHAIN LICENSE PLATE...
Broken connection ETX 90 EC
Yes the stripped bolt can be fixed by you --
Go to this site and search for "Stripped Dec bolt" -- instructions for repairing are on this site--
http://www.weasner.com/etx/menu.html
Also this will help you--
http://www.weasner.com/etx/techtips/etxtu.htm
Oct 23, 2008 | Optics
I know how to fix but can not get the part number
go on the internet and put the model number in and put service manual infact ill get you the part number
the part your looking for are these
there are 4 cogs 2 the same size then a big cog and middle size
the 2 small cogs are 546-9954
the middle cog is 2416-9855
the big cog is 444-0097
all can be purchased at www.seme.co.uk you need to be company but i get stuff from there and just tell them you have a buisness i use blackpool car audio lol
Sep 13, 2008 | Pioneer AVH-P6500DVD Car DVD Player
AEG LAVAMAT 74620 Update Gears on the fill tray have jumped. The primary and idler have to be installed correctly and are fool proof but the third, half gear, needs setting. Can you please supply pic or...
Found this on another site (fixed4free.com) posted by Dave in Jan 2009:
This is one of those things where a picture would be worth a thousand words, but as I can't put pictures on this site, the words will have to do!
- Turn the orange cog anti-clockwise as far as it will go, (putting the nozzle to direct the water to the conditioner drawer)
- Look closely at the orange cog and you'll see that the last-but-one tooth at each end of the row is shorter than the rest. Looking from above and standing at the front of the machine, I call the rightmost tooth on this cog number 1, the short tooth number 2 etc. (my cog has 17 teeth)
- Position the white cog so that (looking from above) the leftmost tooth on the top (incomplete) row of this cog is between teeth 2 and 3 of the orange cog. This should be such that if the white cog rotates anti-clockwise it will turn the orange cog.
Now the difficult bit:
- The shaft that the yellow cog fits on has four vertical 'webs' running down it. Look closely and you'll see that one of these is bigger than the other three. As you would expect, if you look carefully at the centre of the yellow cog it has three small slots and one bigger one spaced around the hole.
- This shaft can be VERY CAREFULLY rotated if you pull it gently upwards against it's spring and wiggle it while twisting it. NEVER force it, the cogs underneath are VERY fragile. If it won't turn, just let go, and try again.
- Look again at the white cog, and you'll see that two of the teeth on the lower (complete) set of teeth have no slot between them, they make a tooth that is 'double width'.
- Look at the yellow cog and you'll see that it has a 'double width' slot on it's lower row.
- The challenge is to rotate the yellow cog's shaft so that you can fit the yellow cog on it, aligning the double-width slot on the yellow cog with the big tooth on the white cog. This is just a case of trial and error, but is the key to getting everything back together.
COMPLICATED BIT OF EXPLANATION!!
The yellow cog only ever turns clockwise and the white cog is a clever bit of engineering allowing AEG to move the nozzle (orange cog) backwards and forwards across the five positions.
The yellow cog turns the orange cog anti-clockwise until it runs out of teeth, then the white cog turns the orange cog the other way.
After a full rotation of the yellow cog, the orange one has moved clockwise to the stain-treatment position and the by-pass beyond, then anti-clockwise back to the conditioner position.
Apr 16, 2008 | AEG Washing Machines
Meade ETX-90EC (325 x 90mm) Telescope Logo
133 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
