Question about Toshiba Televison & Video
Toshiba 42VJ22P showing half picture
Hi. I have a Toshiba 42VJ22P problem. The top half shows picture but the bottom half of the screen has gone black with with a bright line in the centre seperating the two halves. I have sound but for some reason the tv does not respond to the remote control anymore although the remote control still sends a signal as ive tested it. Any advice would be helpful. Thanx in advance
  • 1030 Answers
SOURCE: 3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Posted on Dec 07, 2007
SOURCE: The TV shows light green ring line on the screen.
excellent thanks a bunch
Posted on Sep 18, 2008
  • 41 Answers
SOURCE: The screan is dark on the top and bottom and color is strong
This not the correct Model #, this model is a DLP set and does not have picture tubes and associated lenses. Did you remove the mirror? Does your set have a fold in back? I suspect the back is not fully out in the correct viewing position.
Posted on Dec 21, 2008
daniel719
  • 240 Answers
SOURCE: half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Posted on Jan 13, 2009
  • 375 Answers
SOURCE: image on top half of screen is gone. It seems to
The LCD inside the projection unit is broken - nothing you can do about it - it needs replacing.
They are built in two halves to give you higher resolution and quick image response. One is working, the other is broken. You will need to get it serviced.
Posted on Aug 20, 2009
My JVC model AV-20F476 has a black-out box that covers most of the bottom half of the screen.
Go into menu and under CLOSED CAPTIONS look to see if TEXT is engaged---if it is set to text 1 turn it off or to text 2,3,4, etc
Text was a feature never really used but it is there, some cable boxes also have this setting/feature.
Let me know if you have questions.
Jan 11, 2012 | JVC Televison & Video
Only TOP half of picture shows, rest is black???
No,problems u discribing the LCD screen panel some how it shorted and dead.Replacing the LCD screen panel is not an option,because LCD screen panel are 90% of the tv,so replacing it.LCD screen panel will cost the same as a new tv,because LCD screen panel are limited produced by the tv corporations.It time to buy a new tv.
Jul 31, 2010 | Toshiba 32AV502R LCD TV
When you turn the TV on the screen splits in two,
it sounds like one of your buffer boards are going bad. these are the boards that help put the picture on the screen. there are 2 boards an upper and a lower board. if you remove one and turn the tv on you will get half a screen. see then if you get the lines. please leave rating after you check.
May 10, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Half screen showing picture other half showing color lines
This is a catastrophic and known failure of older Toshiba sets, not much you can do, try to take out a retrospective extended warranty, wait a month and claim, good luck.
Apr 19, 2010 | Toshiba REGZA 52RV530U LCD TV
Half picture shows up and top portion is black
The camera firmware should be reloaded, if this fails then the camera is likely beyond end user servicing and should be repaired by a professional.
The reason your only seeing bottom half is as the reflex mirror is opening upwards to expose the sensor ( traditional cameras opened the mirror then a shutter to expose film ) your cameras sensor is only registering or transferring the bottom half of the image because it is the image is registered bottom first to the top until the shutter closes and the mirror returns to resting position.
Your problem could be the result of firmware or a more serious issue.
Aug 10, 2008 | Nikon D40x Digital Camera
Old tv only shows half picture
it looks like some caps are bad in the set.
Have it serviced by a TV repair shop
Aug 02, 2008 | Televison & Video
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
