Question about Epson Stylus C62 InkJet Printer
Page prints with stripes .Is this a question of cleaningtheprinter heads? How?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 308 Answers
Cleaning the heads will only make matters worse unless you are an expert. try changing the cartridge. good luck
Posted on Jul 04, 2010
What could be causing my Xerox 660DN printer to print stripes down the center of the page?
This is usually the print heads are not working correctly.
Either purge forever and the problem might go away, or call in Xerox.
Good Luck.
Aug 11, 2014 | Xerox Phaser Office Equipment & Supplies
Heavy black stripe on back side of every printed page
This is probably due to miss alignment, there is an option of test page which will be scanned to allign the cartridge, if ur's a all in one printer. This test page is printed at the first time and scanned instantly for first time operation.
Thankyou
Mar 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Stripes all over page
one or more of the cartridges will most probably be out of ink, make sure all cartridges contain at least a 3rd of ink and if they do then perform a head clean followed by a nozzle check, if the nozzle check print is not perfect then do another head clean nozzle check & repeat the process until you get a perfect print on the nozzle test pattern.
If that is not the issue then I suspect driver corruption and you will need to un install then re install your printer drivers
Jan 14, 2014 | Epson Stylus RX500 All-In-One InkJet...
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Printing quality suddenly deteriorated
You could have printhead problems but I would offer that you do a deep clean and consider replacing cartridges with OEM
Nov 13, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Possible Print Head Issue
Select the Jet Substitution Mode.
  1. On the Control Panel, select Troubleshooting, and then press the OK button.
  2. Select Print Quality Problems, and then press the OK button.
  3. Select Eliminate Light Stripes, and then press the OK button.
  4. Select Jet Substitution Mode, and then press the OK button.
  5. Follow the Control Panel prompts to select the color and malfunctioning jet number indicated on the Light Stripes Test page.
Mar 25, 2008 | Xerox Phaser 8550DX Laser Printer
Printing in stripes
Possibly time to replace the printer.
Mar 07, 2017 | Canon Pixma MP500 All-In-One InkJet...
Epson Stylus C62 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
