Hello! i got gateway notebook 7100 with broadcom wireless utility.how can I use my wifi connection? thanks in advance for any help you can give me.
  • 487 Answers
Bottom right hand corner of your screen, right click the icon for networking and enable wireless
Posted on Jul 04, 2010
Gateway 600yg2
I may not be understanding what you are stating, so bear with me;
1) The Wireless Modem antenna wires are up in the Display Assembly,
http://www.mundocorp.com/shopexd.asp?id=1160
In otherwords they should already be there.
2) The 802.11 Mini PCI Card, is a Wireless Module.
It goes in the Mini PCI Compartment, under the Mini PCI Compartment Cover, located on the bottom of the laptop.
It's made by Broadcom,
(Gateway 6002672 part number)
http://support.gateway.com/s/Mobile/NETWORK/Wireless/6002672/6002672mv.shtml
See at the Top right where it states Main, and has a white Side Arrow?
This terminal is where the Black wire (Lead) of the wireless antenna connects to.
The other terminal, AUX, is where the White wire connects to.
http://www.laptops-we-r.com/prestashop/gateway-6000-parts/418-gateway-dell-broadcom-bcm94306mp-b-g-mini-pci-wifi-card.html
Here is the Service Manual, (PDF file form),
http://support.gateway.com/s/Mobile/Gateway/600YG2/8508798.pdf
Page 13.
REMEMBER, remove ALL power. Remove the AC adapter (Charger), and Battery, before working on the laptop. Also follow Anti-Static Precautions.
Regards,
joecoolvette
Aug 20, 2012 | Gateway Computers & Internet
I have an acer aspire 5733. I have been trying to connect to a wireless connection. It has no button to switch the wireless on, l use the function key plus wireless. When I press the button it does no show...
Wifi needs utility to scan the hotspots before you can connect to any one of them. Utility maybe in control panel as wireless(not IR). Then you can see the wifi icon in system tray next to the time and date.
Feb 29, 2012 | Acer Computers & Internet
Hi, I have a HP Compaq nx6110 with Broadcom wireless adapter, and I have a Wireless problem. I've recently reinstalled my OS, it's a Win XP SP3, and ever since my wireless adapter wont start, it...
  1. Make sure to press the WiFi button on your notebook. You should see a blue light if your WiFi adapter is on.
  2. If that doesn't work, download and install the latest version of the wireless adapter driver.
    http://bit.ly/lrDIcL
May 07, 2011 | Computers & Internet
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
What is my wifi driver?i cant find it..so please help me
please locate the wireless driver for your gateway notebook on this link
hope this helps . . .
Apr 05, 2010 | Gateway MX3225 Notebook
Gateway M305 Internet Connection
The Gateway m305 has 3 WiFi hardware options, 2 Broadcom and 1 ActionTec. I have found at times that the wireless adaptor will have its own control and configure software running and it will not allow windows to manage it. If this is so you can manage the connection with the manufactures software or find the option in network connections in the properties of the wireless adaptor to allow windows to manage it. Either way should allow you to connect but I prefer to use windows management. I hope this is of some help. Good Luck
Jul 21, 2009 | Computers & Internet
My wifi is not working
Download from here
http://www.notebookera.com/notebook-drivers/Compaq-Presario-C700-CTO-Notebook-Broadcom-Wireless-LAN-Driver_99614.shtml
Apr 04, 2009 | HP Computers & Internet
Network Controller Driver Missing Gateway M405
Well, you can directly try Driver Detective and let the software have a free scan to automatically detect & update the missing Gateway drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues.
Best wishes!
Mar 29, 2009 | Gateway M405X Notebook
My wireless laptop gateway won't connect to my router again after going out of town using it at hotel and now it wont connect at home. it will connect on my job with no problem
Hi!
It is possible that the wifi networking where you connect in the Hotel use the same name of you home wifi network!
Try deleting your wifi profiles and reconnect again.
If you don't know how to delete the wifi profiles let me know and I tell you.
Thanks!
Feb 18, 2009 | Gateway MT3705 Notebook
My Wireless Broadcom Adapter is not properly running
here is the drivers and utilities page for your laptop.
http://support.acer-euro.com/drivers/notebook/as_4310.html
just download new drivers and restart.
go to your os then drivers and utilities tab then wireless broadcom and
lan broadcom.
Dec 26, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
