Question about Lands Phones
How does one synchronize the cordless unit and the base unit in a beetel CB 12000? My base unit is working perfectly but the cordless set shows no response at all. It is charging perfectly but when I take it off the cradle, it just does'nt work. Thanks
Hi buddy, I am facing same problem. Did u get any solution of it,Can you send me manual of CB 12000 model. My daughter has destroyed it long time back. So, if you could send me solution and/or manual on hitesh.singh@gmail.com
Thanks buddy Hitesh
Posted on Dec 29, 2010
Had a att el52300 base that went bad so bought another one it seems to be working ok. all head sets have out of Range or no Power at base.Tried to clear with answer given but nothing worked Need help
Try the following:
1/ Make sure the power cord is securely plugged in at the base and that it's powered on ie: light is on and working etc..
2/ Reset the telephone base. Unplug the electrical power. Wait for
approximately 15 seconds, then plug it back in. Allow up to one minute for the cordless handset and telephone base to reset.
3/ Place the cordless handset in the telephone base for one minute to allow the cordless handset and base to synchronize.
Manual available here:
at&t el52300 manual
-Charles
Jul 02, 2016 | AT&T El52300 Cordless Phone
Beetel telephone
The noise could be caused by a dirty phone line connection at the wall socket. Clean any corrosion off the contacts on the phone wall socket where the phone base station lead connects into the wall socket.
May 21, 2013 | Lands Phones
I have a Uniden cordless phone #D2CT 6.0--I love the phone but the party on the other end of the line can barely hear me -how can I fix this or this a bad phone???
At 20 ft line of sight, you should have perfect reception with most any cordless phone.
The fuzzy signal can indicate:
1.
A weak signal between base and handset.
20 ft line of sight should have a good strong signal.
Your handset may be defective.
Or, your handset battery may be weak.
Your base unit may be defective.
2.
You may be experiencing RFI Interference.
Is the base unit next to any other electronic devices?
If it is next to a wireless router or some other wireless device, it may be overloaded by the nearby signal (even if on a different frequency)
I've got a 5 year old Panasonic 5.8 Ghz cordless phone connected to my VoIP box. I just tested it from about 25 ft away from the base unit in another room with a wall in between and my reception is perfect.
I did the same test with my Panasonic DECT 6.0 phones (1.9 GHz). The first handset is slightly fuzzy, but otherwise good signal. The 2nd handset was perfectly quiet with good strong signal. So, there is a difference between two identical handsets connected to the same base unit. This indicates to me that one handset is better tuned than the other. Nothing I can do about that but get a new 2nd extension cordless handset. Sometimes, it's just luck of the draw
Feb 15, 2011 | Uniden DECT 6.0 Cordless Phone ID
The cordless mouse just stopped working. Tried replacing battery. No luck. Any suggestions? Thanks!
Have you tried to synchronize witht the base unit connected to the computer end. Are there small buttons on top or underside of mouse and base unit. You have to press these together and let go. It would be helpful if you provide the product number of the Logitech mouse so that i can look up the details and confirm. They make several models.
Feb 11, 2011 | Logitech Cordless Mouse
Master phone is okay; slave phones show screen as "UNAVAILABLE" and beeps with error code sound...I can't find a resolution in the owners manual
That sounds like you have to synchronize it with the base unit.Put the slave phones in the base unit and try them.It may take 2 seconds,it may take a minute.It should work though.If you have already tried it and it still does not work,just comment here and I will get an autolink to what you posted.Good luck,Greg
Oct 29, 2010 | Uniden Cordless Phone
I have bought a GE cordless phone model 29670, base unit working fine but cordless unit no sound or display even though battery charged more than 10hrs before first use.
I took the phone to the shop where I purchased, they replaced the battery cordless unit with a new one, now it is OK. All displays are perfect.
Thanks & regards
Balakrishnan.
Oct 13, 2009 | Uniden Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Vtech ia5870 dual handsets model problem:
http://www.vtechcanada.com/manuals/5870ciben.pdf
from the troubleshooting section of the manual
• Unplug the base unit’s electrical power and remove the battery from the handset. Wait for 15 seconds then plug in the battery place the handset in the base unit and plug in the power. Allow up to one minute for the cordless handset and base to synchronize
not a guarantee, something to try
Aug 30, 2008 | Vtech ia5870 Analog Cordless Phone
Lands Phones Logo
293 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
