Question about GE Monogram ZDI15C Automatic Icemaker
Hello. I have a GE Monogram ZD115 ice maker that makes ice slow
Hello. I have a GE Monogram ZD115 ice maker that was manufacturered in 2002. It was working fine and then all of a sudden one day it started working poorly. I have not found any obvious problem. It will run and operate but it makes ice very slowly. It seem to take a long time for the sheet of ice to form on the plate amd be released to the cutting grid. When it is released, it appears thinner than normal. The machine runs constantly, but will not fill up with ice. It can only manage to maintain a small amount in the ice bin. Do you have any ideas or suggestions? Thanks.
  • GE Master
  • 11,800 Answers
All your problems appear to be caused by a leak in the circuit = it has caused the partial loss of the cooling fluid/freon so the freezer is struggling. The entire circuit must be checked, the leak identified and plugged, the circuit purged and refilled. This is a job for a pro, specialized equipment is required. Don't wait too long or the fluid will be completely lost and the compressor will burn running on empty.
Posted on Jul 04, 2010
  • judianddom Jul 04, 2010
    Thank you for the response. Your assessment sounds reasonable. However, how do you explain that it seemed to develop this condition overnight? Do you think the leak just occurred? I am a bit skeptical since it seemed to be sudden. Thanks.
  • Azrael SRL Jul 04, 2010
    The compressor vibrates quite strongly when in use, this is why all pipes leading to it are made out of a special copper alloy that is very tolerant of vibrations. Unfortunately even these pipes can handle so much so one will eventually fail. When the pipe cracks it will be sudden and on a big scale so yes, it will appear as a fault out of nowhere. Your fridge is about at the age when this type of problem appear so when the repairman will come tell him to check very carefully the other pipes - on the ones close to failure you can see the stress marks as a discolouration ring on the pipe.
Ziss420driss ice maker
Hello there... what is the make and model of your ice machine?
Jun 24, 2014 | GE Monogram ZDI15C Automatic Icemaker
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Zd115
Part number AP3865361 whirlpool same as ge
Jun 24, 2013 | GE Monogram ZDI15C Automatic Icemaker
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Ice cube maker makes ice cubes ever once and a while, the condenser fan turns slowly. is this why it doesn't make ice cubes and the frezzer side is not cold enough? condenser fan going out? monogram...
Good day,
The ice maker speed of production is determined by the freezer temperature. If the freezer temperature is warmer than normal then the cycle thermostat in the ice maker will take longer to reset for the next harvest, causing low ice production.
More important, the condenser fan motor running too slowly can cause the compressor to run overheated and cause serious and expensive damage.
If in your opinion, it is running too slow, the issue should be addressed as soon as possible.
Aug 05, 2010 | GE Monogram ZISS480DRSS Stainless Steel
I need a water valve for a Monogram zd115 Ice maker. Where should I buy one. and what about a part number??
If you have the model number of the machine, or the old part in hand, you should be able to get your part at any appliance parts supply house (look in the yellow pages). It is better IMHO to take the part with you to the store.
Best regards, --W/D-- please feel free to rate this solution - thanx!
Aug 04, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZDI15C Automatic Icemaker Logo
424 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
