Question about Airhead Kwik Tek Hot Dog 3 Person Towable
Kwik Tek airhead hot dog right side tube has a hole in it. are there replacement tubes?
My airhead viper 2 inner tube has a hole, how do i fix it?
If this is a natural rubber tube,the good old bike patch kit will do.If it is a vinyl tube,there is a type A or type B.(Different chemical makeups in different types of vinyl will only adhere to the same type).I don't know how to tell which type of vinyl is which,so get one of each type(at a sports eqipment store).If the first one doesn't adhere,you should be able to clean it off and try the other kind.
Jun 12, 2012 | Vehicle Parts & Accessories
Can you purchase a replacement inner tue for airhead mega slice?
Cynthia,
I have the same tube and looked around and found nothing... but luckily we were within 90 day warranty period and Kwik Tech sent me a replacement air bladder. If you're not so lucky you'll have to buy the whole thing again. But if you cover is in good shape you could always sell it on ebay and help offset the cost of the new tube. I would be willing to bid on it... my cover is getting worn. robloch at hotmail dot com Hope this helps.
Jul 15, 2010 | Kwik Tek Airhead Megaslice 4Rider Tapered...
What is the best way to patch a small hole in a towable tube
Your local sporting goods store should carry a patch repair kit that should work perfectly.
Sep 09, 2009 | 3M SportsStuff Speedzone 3 Inflatable...
Where to buy replacement caps
overtons, boston valve, 4.99
Aug 26, 2009 | Water Sport
Airhead 3 person tube
Put weight (people) on the rear of tube as far as possible and start out at full throttle until they are moving sufficently to stay on top of the water. Make sure tube is fully inflated.
Aug 09, 2009 | 3M SportsStuff Speedzone 3 Inflatable...
Replacing tubing for water
1. get the same size tubing and parts
2.check the fitting, take apart both side and put the new tubing again
Jul 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
Airhead Kwik Tek Hot Dog 3 Person Towable Logo
144 people viewed this question
Top Airhead Water Sport Experts
Tom Chichester
Bill Boyd
Are you an Airhead Water Sport Expert? Answer questions, earn points and help others
