Question about Goldstar MV-1526 Microwave Oven
I have a Goldstar microwave and it is not heating up the food. It is running the lights are on the tray is rotating but the food is not heating up at all.
  • Goldstar Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101//./.
Posted on Mar 27, 2011
What would cause the glass tray in the microwave to shatter
  • The glass tray had a hairline crack or stress fracture that was not visible
  • It got a little too hot in one area
  • The expansion from the heat caused the fracture to expand and therefore crack and break
An accidental bumping of the microwave plate on the countertop while going from the microwave to the dishwasher might set up the above situation. The spoon your seven year old left in the mac and cheese might have arced and nicked a small piece of the glass. Whatever the cause, microwave trays break and they break for a lot of reasons.
All foods cooked in the microwave produce heat. Microwaves themselves are not hot, but the foods cooked in a microwave get hot - some much hotter than others.
Even though most microwave glass trays are tempered, they are not designed to hold up under high temperatures. You will see most microwave trays stamped with the words "For microwave oven use only" This is to let us know that it's probably not a good idea to use the trays in a conventional oven.
Any air pockets, cracks or gaps in the glass can enlarge under heat. Since glass isn't very receptive to being stretched, breakage can occur.
for more you can read on this link
http://www.ebay.com/gds/Why-did-the-glass-tray-in-my-microwave-break-/10000000003014864/g.html
Aug 27, 2013 | Goldstar Microwave Ovens
Microwave not heating food model MA795B
1 door interlock
2 diode
3 magnetron
4 heat censer
5 dry joint on relay on timer board
6 Re: Jeff
Apr 12, 2012 | Goldstar Microwave Ovens
My Goldstar MV1608 stopped rotating and heating food yesterday. All other functions seem to be operating such as the light, fan, panel, etc. It is 18 months old. How can I fix it?
If there is no heating it is possible that the MAGNETRON has failed provided there is supply feed to the unit when the microwave is powered. Normally the magnetron along with the fan and light comes on when the microwave power is triggered. So since the rotation is absent it is possible that there is no power feed from the processor board which can be related to a driver failure. You need to check the output from the PROCESSOR to confirm and pinpoint the defective component. Check the relay to the magnetron trigger as this can be a suspect.
Oct 24, 2011 | LG MV1608WW Microwave Ovens
I have an old Goldstar microwave (MV1140T) that just stopped heating. The fan still works but the food won't heat up. What can I do?
The problem is caused by a bad magnetron, "common problem" or the high voltage capacitor and diode, all three work together to heat the food. The repair cost for parts and labor will be high enough to consider buying a new microwave oven.
Feb 23, 2011 | Goldstar MV-1501 Microwave Oven
Goldstar GMV1540TB Microwave is not heating. Timer works but the tray is not rotating. If pushing the door up the oven can heat but easy to stop heating.
heatman101=-=-=--
Jul 14, 2010 | Goldstar MV-1526 Microwave Oven
Tray is not rotating when the microwave is operating?
heatman101--=
Jul 16, 2010 | Whirlpool MH1150XM Convection/Microwave...
I have a 2001 GE Spacemaker #JVM1840CD001 that does not heat anything, but runs. What's wrong and how can I fix it?
If your microwave oven "works" meaning that your display, cooking tray rotates, and the light turns on when you open the door, but does not heat the food, the problem usually is with the magnetron circuit. If you hear a loud hum when you try to heat something in the oven usually means that the magnetron has failed. The replacement magetron is about the same price as a new oven, so you are better off buying a new oven.
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Viking 1100 watt Microwave will not heat food
Microwave Oven Basic Troubleshooting Tips
heatman101
fjj
Jan 05, 2010 | Viking VMOC205SS Microwave Oven
Tray does not rotate and no heat at all
the thermal fuse (if present) is open. the motor is defective or shorte.
Aug 29, 2009 | Goldstar MV-1501 Microwave Oven
I have a Sharp Carousel convection microwave, model#R930AK-F. Built in NOV< 2005. The fan runs, the tray will not rotate, and it does not heat food.
microwave's have fuses in them. try and replaceing them before you call the repair man.check on the web. for locations of fuses,hope this helps
Aug 05, 2009 | Microwave Ovens
Goldstar MV-1526 Microwave Oven Logo
278 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
