Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Fitting new gearbox to 8444d
How do i remove the gearbox from 8444d cordless drill
  • 90 Answers
That is a pain. when you take them out they have to go back in that specific way that specific place. if you don't get back just right the case won't fit back together. if you take it slow and only remove what you need to remove you may not have any trouble. you will have to remove all the case screws to get to the gearbox. everything is a tight fit.
Posted on Aug 29, 2010
How do you change the brushes on a bosch 36 v-li
Once you have removed the 4 screws holding the gearbox to the main body take off the right hand half of the housing leaving the left half on the work bench. Unscrew the 2 screws that hold the brush holders down and remove the old brushes and refit with new ones. Rebuild in reverse.
Oct 24, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
My Dw056 impact is about 3 years old. its starting to die. it wont impact and its very weak. is there a repair for this to bring it back to life
Hi, There is a repair in which you would have to have the gearbox assembly replaced in order for it to operate as new again. To be honest when you compare the price of replacing the part plus the technicians fitting cost to just buying a 'body only' drill, that has no batteries or charger and is brand new with a warranty..i would personally go for buying the new drill as i think there would be hardly any difference in cost. Good luck and i hope i was of some help to you.
Jan 15, 2011 | Dewalt DW056 18 Volt Cordless Impact...
How do I change the keyless chuck on a cordless drill/
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting if this drill has a 2 speed transmission. Remove the battery! I have performed this with the battery in back in my noob days, and getting an allen wrench in your rib because you accidently hit the trigger will only happen once. You will never forget that experience. Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. You have only a few to several attempts at this before you risk damaging the clutch, so make the first one count. Follow through like you are attempting to hit something 6" below the allen wrench. If this does not do the trick before you shell the clutch/gearbox, you are looking at an expensive undertaking, most likely a new drill. I have only shelled 2 clutches out of literally tens of thousands of chuck repairs, so don't worry, just be aware. Let me know how it goes!
Nov 23, 2010 | Black & Decker 18V Cordless Drill/Driver
Makita 8444d second and third gears sound noisy and do not engage
I had the same problem on my 8444, it was out of warranty (just over 2 years old) so I stripped it and found the plastic gear selector ring worn out. Was livid at this as these drills are marketed on the strength of the "all metal" MXT gearbox! Makita UK, to their credit, sent me a replacement gearbox free of charge when I pointed this out to them.
A year on and the replacement gearbox has now started doing the same in 3rd (high) gear. Doubt I can get another free 'box out of Makita (they would probably say I fitted it incorrectly) so am looking at buying just the drill body, which comes out at around £60 and will work with my existing batteries. Just not sure if I would trust the replacement not to fail, but a similarly powerful drill with 2 batteries would cost me wel over £200.
Jul 20, 2010 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
I have a three year old hitachi dv18dl cordless hammerdrill. The low gear is stripped and the trigger is intermittant. I tried taking it apart but saw nothing obvious. Any ideas on what to do or where to...
http://www.ereplacementparts.com/hitachi-dv18dl-18v-30ah-lithium-ion-cordless-hammer-drill-parts-c-7927_13467_13346.html
Here is the diagram for the drill. I would replace the gearbox and dc control switch. But it may be cheaper to buy a new drill.
Nov 25, 2009 | Hitachi Dv18dl 1/2 18v Cordless Hammer...
Chuck jaws on Makita 8444D fell out
There is suppose to be a flat head Left hand thread chuck screw in there. It may have fallen out. You will not be able to put the jaws back into the chuck. You will have to replace the chuck with a new one. If you make sure that the chuck screw is not there you can remove the chuck with a couple of steps. Make sure the drill is in it's lowest gear. Use a strap wrench or some large vise grips on the chuck. If there is still one jaw in the chuck make sure it is all the way open and locking the collar to the chuck. The chuck will come off in the regular lefty loosey configuration. It may be stubborn. If this is the case, You may have to cut the collar off the chuck and use a pipe wrench. Or bring it to a professional to get it changed out.
Sep 23, 2009 | Makita 18 Volt Cordless Hammer Drill Kit ...
Makita 8444d mxt drill
what is the setting in your clutch. if you set the clutch to the highest setting and it`s still slipping then you need transmission assy.
May 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
409 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
