Question about Compaq Presario V4000 Notebook
Wedged Battery My battery is wedged and won't come out. Took to a shope and they can't get out either, only suggestion was too pry and said it might cause some external damage, any idea's??
    Sergeant:
    Champion:
  • 293 Answers
You have to force it to remove your battery. in some extent it will be damage but you have to remove it in anyway.
Posted on Apr 17, 2008
Why does it go-stop-go-stop?
The Controller maybe over heating. another thing that could cause this is loose connection to the battery. Throttle may have broken wire and when you hit a bump looses connection. If you let the scooter sit for 10-15 min. before trying again that could have worked better for you.
Mar 30, 2016 | Pride Victory 4 Wheel Scooter
I don't know how to remove battery from this phone. Help.
take the back of the phone off, the battery is nearly impossible to pry out til you get practice but use the rounded corner of the metal back that you took off and put it in the little space on the top of the battery and wedge it in and pry up. keep trying, it will get easier lol
Mar 31, 2011 | LG Shine KE970 Cellular Phone
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
On my Fujitsu Siemens laptop the battery symbol is flashing orange, does anyone know what this means?
This means you're running out of battery. So you need to switch on to its adapter and plug it to the power source to let it charge.
Jul 23, 2009 | Computers & Internet
My batter is wedged
The best way to get at this is by taking the plastics apart. You want to get to a point that you can see the back of the battery so you can push it out instead of prying it. Start by removing the keyboard, then the top plastic that hold the touch pad and surrounds the keyboard. At this point you should be able to see the back side of the battery pretty well, make sure nothing has fallen into the battery bay that has made the battery kick off to one side. You should be able o work it out from there.
Apr 17, 2008 | Compaq Presario V4000 Notebook
Indesit wie1373 won't spin won't open
took off the filter cap to find hair clips wedged inside stopping the action. Had to look really hard with a torch . many thanks to all suggestions saved us lots of cash
Apr 10, 2008 | Indesit Washing Machines
Sony z525a
i had the same problem for a long time. took a piece of paper and wedged it at the top of the battery to force it tighter to the battery contacts at the bottom and the problem went away for the most part. Prior to this fix, my phone would 'reboot' itself or turn itself off several times a day...
Jan 18, 2008 | Cell Phones
Problem 4 my motov3
pull the back off and removed the battery. Refit the battery and push the cover back on. Suggest you try the back cover, if it's even a little loose the battery can move and you will loose power...
the slightest movement of the battery within the phone was the course of the problem,.
So what I did was fold up a tiny piece of paper and place it at the top of the battery between the battery and the casing, this wedged the battery into the casing a lot tighter and I also made sure that the battery cover clicked into place good and proper.
Oct 18, 2007 | Motorola Mobility RAZR V3
Sidekick 3 power on and off
mine used to do that and it might sound funny but i took the back off and wedged a piece of paper to hold the battery still. mine work perfect now. i hope it helps
Aug 20, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Compaq Presario V4000 Notebook Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
