Question about Brother P-Touch 1180 Label Printer
P-Touch XL 30 When I press print the the text FEED:Full appears I can scroll through the selections and they are the default settings. When I press the return key "Working" flashes but no label is printed. I printed 2 labels and then this started happening ?????
When FEED: Full flashes in the screen, just hit return and it will print out.
Posted on Jul 22, 2010
I have HP LaserJet Enterprise 700 color MFP M775dn ptinter and i forgot the username and password to access the setting through the web, any way to reset it please ?
You will need to perform a partial clean. Turn off the printer. Turn it on and watch to boot up on screen closely. When the black line appears under the HP logo, touch the HP logo. Display will go to a black and blue display. Use the arrows on screen to scroll down to administration, select partial clean and press ok, and then press back arrow until continue appears on screen. Press ok and unit will restart. You will lose most of your settings this way but you have no other choice.
Oct 21, 2016 | HP LaserJet M775DN Laser Multifunction...
My colors are printing separately, divided and do not overlap or blend. I use a Roland 540 printer, and I have replaced chips, motherboard, and encoder sheet. What would cause this?
If a gap is present decrease the value by going to Menu, Calibration, Setting and pressing the Down Arrow to decrease the percentage shown to match what setting is best on the test pattern. Press Enter to save the value. If the printer does not show multiple test patterns perform the Feed Calibration, Test Print again to check the results.
If an overlap is present increase the value by going to Menu, Calibration, Setting and pressing the Up Arrow to increase the percentage shown to match what setting is best on the test pattern. Press Enter to save the value. If the printer does not show multiple test patterns perform the Feed Calibration, Test Print again to check the results.
Tech Tip: The Feed Calibration is a very fine adjustment meaning that an incremental adjustment of .05% or 10% is very small. Some media will require an adjustment in much larger steps.
Note: The Feed Calibration setting on the printer will be overridden by Versaworks as a default. This can lead to a very confusing scenario where the Feed Calibration setting doesn't appear to make any adjustment. Please see the next page for information on setting the Feed Calibration in Versaworks.
Once the proper Feed Calibration has been established on the printer it is important to make sure this setting is correct in Versaworks. Once Versaworks is open and a job has been loaded, perform the following steps:
A. Double click on the print job to bring up the Job Settings window and set up your media size, copies and other relevant items under Layout.
B. Select the Quality tab and Select the proper Media Type for the job. This step is critical because the Feed Calibration is tied to the type of media being used. When the Media Type is changed the Feed Calibration setting will change to the setting which is default for the Media Type.
C. Next select the Printer Controls tab on the left hand side and under Feed Calibration Controls choose Use Printer Setting.
D. Select OK to save the settings.
Tech Tip: In step C you can also select Use Custom Settings and enter in a value for the Feed Calibration. This allows for making corrections to the Feed Calibration without changing the settings manually on the printer. If you choose Use Default Media Settings or Use Custom Settings the value that has been set on the printer will always be overridden.
Tech Tip: In addition to having multiple test patterns which make for a quick and easy selection to be made the RS, XJ & AJ printer models allow adjustment of the Feed Calibration mid-print by taking the following steps:
A. Press the Menu key
B. Scroll to Calibration, Setting and pressing the Down Arrow to decrease the percentage shown or Press the Up Arrow to increase the value.
C. Press Enter to save the change in value.
Jan 18, 2011 | Office Equipment & Supplies
Its prints one page at a time and a pop up appears that says "press cancel button (manual feed mode)". I do this and nothing happens. Why will it not just print the entire document at one time? I...
You need to change the default tray. Thats the reason its printing one page at a time. You can change the default tray to draw paper from two ways, by using the controls on the printer itself or by changing the settings when you print a document.
To change it on the printer, go to menu on the printers keys and scroll the options until you find the print settings. Use the up and down arrows to scroll and press enter or OK when you find print settings. Continue to scroll until you see the default paper tray and change it from the manual feed choice to the default paper tray.
If changing from the print settings in the computer, when in a document that you want to print go to file at the top of the page and then print and click on preferences. Click the tabs at the top until you see the paper tray that is currently being used and click the arrow next to it to change it to another. Then click "ok" and close everything.
Dec 07, 2010 | Samsung ML 2010 Laser Printer
I have lg su 910 i forget my input password s.n/ 906kphg0179777 plese hhhhelp
Reset Default
From the standby screen, press Menu.
Scroll to and select Settings.
Scroll to and select Reset Settings.
Scroll to and select Master Reset.
A confirmation screen will appear, select Yes.
Enter Security code, press OK.
NOTE: The default security code is 0000.
Clear memory
Scroll to and select Master Clear.
Scroll to and select desired option:
Handset
Memory Card
A confirmation screen appears, select Yes.
Enter security code, then press OK.
NOTE: By default the security code is 0000.
Dec 05, 2010 | LG Shine KE970 Cellular Phone
Printer using small type font size when printing from web pages
I am sorry to say that font size cannot be changed from the All-in-One software. It can only be changed from the application which you are using to print.
you can use Smart Web printing software to print webpages:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00793678&cc=us&lc=en&dlc=en
also, perform the steps below:
Change Text Size in Internet Explorer
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Size" option from the drop down menu. Use the mouse or press the x key.
A sub menu option window will appear containing the following five choices: "Largest", "Larger", "Medium", "Smaller" and "Smallest". "Medium" is the default value.
3. Select from among the five options by using the mouse to highlight or by pressing the appropriate keyboard letter, i.e. g for "Largest", l for "Larger", m for "Medium", s for "Smaller" or a for "Smallest."
The size of the text displayed in the browser window will change in accordance with your choice.
Change Text Size in Mozilla/Netscape 6+
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or Windows users can press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu window will appear containing three sets of options for changing displayed text size:
a. Increase or decrease the text size by small amounts. Select either the "Smaller" or the "Larger" option. Use the mouse to select "Smaller" or "Larger"; alternatively, press the appropriate
shortcut: CTRL - (minus) for "Smaller", CTRL + (plus) for "Larger". The size of text displayed in the browser window will increase or decrease by small amounts in accordance with your choice.
b. Change the text size to one of 7 pre-defined percentages of the default: 50, 75, 90, 100, 120, 150 and 200 percent. Select from among the 7 pre-defined percentages. Use the mouse to highlight your choice or the appropriate keyboard short cut, i.e. 5 for 50%, 7 for 75%, 9 for 90%, z for 100% (the default), 1 for 120%, 5 for 150% or 2 for 200%.
c. Change the text size to an arbitrary percentage of the default, e.g. 300%, 37.5%.
Select the "Other Options" menu item. Use the mouse to highlight your choice or press the o shortcut key.
A pop up input window titled "Text Zoom" will appear.
Type in the percentage amount by which you wish to change the default text size. Click on OK or press the ENTER key.
The size of the text displayed in the browser window will change in accordance with the value you enter in the input field.
These three options may be used separately or in combination.
Change Text Size in Firefox 1.0
1. From the Firefox Menu Bar select View>Text Size>Increase
2. This will cause the text to display on the web page one size larger. However this is a temporary change.
Or use the keyboard:
1. Press Ctrl & +/-, or Ctrl & scroll down/up to increase/decrease the text size.
To make a permanent font size change:
1. From the Firefox Menu Bar,
a. Windows: select Tools>Options. Select 'General'
b. Macintosh: select Preferences.
2. Click on 'Fonts & Colors'.
3. Set the font sizes. Minimum font size.can also be set.
Change Text Size in Opera
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse to make a selection or press the ALT + v shortcut keys. A drop down menu will appear.
2. Select the "Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu will appear containing the following options: 50, 80, 90, 100 (the default), 120, 150, 200 percent. In addition, there are four more options that make percentage increments or decrements to text size: -100, +100, -10 and +10 percent.
Select from among the options by using the mouse to highlight your choice.
* Alternately, use the + (plus) and - (minus) keys on your keyboards number pad, or the Zoom selector in the toolbar.
Mar 15, 2009 | HP PSC 2355 All-In-One InkJet Printer
How to increase the font size when printing?
Notepad and Microsoft Word
Please perform the steps given below, if you are printing from note pad nd Microsoft word:
Click on Format.
Click on Font.
Select the desired font under Size.
If you are printing from any browser, then I request you to perform the steps given below to change the font settings in differ browsers.
Following are the instructions to decrease or increase the font size in various browsers:
Dec 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer font size
Click on Format.
Click on Font.
Aug 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Size of font on the printed page too small
It depends on the print settings of the application but not All-in-One software.
Please perform the steps below to resolve:
Click on Format.
Click on Font.
Jul 15, 2008 | HP Photosmart C6100 All-In-One Printer
Won't scan legal documents properly
Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Message capacity
Press the centre button, then select messages. Scroll down to 'Text Msgs' then press the middle button. Scroll down to 'Text Msg Setup' then press the middle button. Scroll down to 'SMS default storage' and press the middle button. Highlight 'Phone' then press 'Select'
It should now be ticked and you should have full memory capacity for messages.
Sep 07, 2007 | Motorola (MVME350)
Brother P-Touch 1180 Label Printer Logo
987 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
