Question about Hotpoint NVL333GY Gas Dryer
How do i take it apart to lubricate - Hotpoint NVL333GY Gas Dryer
  • 10,319 Answers
There is nothing to lubricate since the bearing are sealed. Grease and oil travels and will getr inside the drum is most cases. If you do decide to repack the bearings with grease a strong saftey pin is needed to pop out the grease seals on the bearings. If the belt tensioners pulley bearing squeaks, replace that pulley along with the belt.
The top and front panels will have to be removed to gain access to the internal parts. The drum will pull directly out when the panels are removed as well
Disconnect the electric before tearing down
Posted on Jul 04, 2010
Juicer does not turn / rotate. Does this mean the motor is burnt out ?
It could mean burnt motor, but it could mean that it's simply got gunk in it, and it needs cleaning/lubricating. You'd have to take it apart to tell. A burnt motor has a very specific smell. If you take it apart, and there's no burnt smell, likely cleaning and lubricating will fix it.
Jun 10, 2015 | Braun MPZ-22 Juicer
Giotto Aluminum Tripod # 9160 - legs sticking - took legs apart, cleaned but did not lubricate - still sticking.
Call us at 800 735-4373 regarding serving Giottos tripods and for our address to get this properly repaired. It does not need lubrication.
Apr 27, 2011 | Giottos Photography
Why wont my needle stay down on my record
The turntable might need some maintenance - sometimes the mechanical parts will freeze due to dried up lubrication. The arm which guides the needle may be stuck in a certain position. Tear it apart and lubricate the moving parts. Also, check the needle cartridge - it may be broken.
Jan 20, 2011 | Audio Players & Recorders
Drum squeaks, squeals, have taken it apart. belt still has print and is not worn.unbelievably loud. how to get rid of noise?
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Once you have taken the dryer apart and you will now remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
This should solve your noise problem.
For this FREE answer, Please rate me
Oct 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Lubrication
Getting lubrication into a ceiling fan is very difficult unless you take it apart, take it down and then turn it upside down.... Then spray WD-40 in around wwhere the fan blades hook up at. Then let it set for at least a couple of hours to let the lubricant work its way into the bearing. Turn it a bit and spraying more in every fifteen minutes or so will help to get it in there better.
Heatman101
Feb 27, 2010 | Hampton Bay 24002 Ceiling Fan
Dryer making a high pitched squeek, I took apart
I normally don't work on gas dryers but it sounds like the drum rollers are in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 27, 2009 | Amana LGA10 Dryer
Lubricant for coffe machine
Hi, you shouldn't really use any other lubricant apart from the one recommended, but I have used vaseline on a similar coffee machine, and as long as you keep it away from the brewing head, it should be fine. Do not rinse the brewing head in very hot water as it will wash away any lubricant that is there.
Jun 15, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Xbox 360 recognizes games as dvds
The Thing the spins your discs is likely pretty much out of lubricant blame that on microsoft... it causes the disc not to spin correctly and it doesnt get the disc spinning fast enough. Only way to fix it is taking it apart and lubricating it you will have to search the internet for the tools and instructions on how to take it apart
May 31, 2009 | Microsoft Xbox 360 Console
Hozelock Auto Reel
I took it apart by unscrewing the 2 halves of the plastic cover making sure the hose was fully wound up as the spring mechanism can be dangerous. Extreme care must be taken. I can now get lubrication on to the spring. The manufacturers will not tell you how to do this due to health and safety rules.
Sep 29, 2008 | Hozelock Garden
Lubricant
I think, lubricant is not so intelligent to reach there.
Jul 07, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Hotpoint NVL333GY Gas Dryer Logo
114 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
