Question about Sony Cyber-shot DSCW210 Digital Camera
My sony cybershot will not recognise the sony pro duo 8gb memory card I have been using?
  • 455 Answers
Hi Nick,
The DSCW210 Camera is compatible with the Memory Stick ProDuo up to 32GB. The Camera will not recognize the Memory Stick if it is formatted in the Computer. Try removing and reinserting the MS and check if it helps. Try using different MS to check if the issue is with the MS or with the Camera. Try resetting the Camera and check if it helps.
Performing a manual power reset may help:
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Reset the camera to factory specifications to try resolving the issue.
Thanks.
KenSolutions
FixYa
Posted on Oct 23, 2010
DSC-H2 will not accept memory card
The DSC-H2 works with Memory Stick Duos, not with Memory Stick PRO Duos.
Nov 26, 2013 | Sony Cyber-shot DSC-H2 Digital Camera
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
When i put my sony PRO duo 8gb memory stick into the slot on my computer, the light does not shine green and my computer acts as if it's not even in it. PLEASE HELP A.S.A.P.!!!! Thanks, admlmbrtrckz
Jan 24, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Not able to copy movies on Sony 8GB Memory Stick Pro Duo for PSP
Before you go throwing any old video file onto your PSP, make sure you have the following items:
  • The PSP. This is self-explanatory.
  • The .MP4 video files.
  • Video conversion software to convert non-MP4 files to MP4, the format the PSP reads.
Oct 20, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
My sony memory stick pro duo doesn't work
It sounds like the software on the card has suddenly dissappeared. Try downloading the software from sony back onto the card. Let me know if this helps.
Jun 19, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
Memory Stick Pro Duo 8GB on PsP
Two possibilities.
1. The firmware on your PSP is too old to recognise the 8GB (only recognises up to 4GB).
2. If firmware is up to date you have a fake memory stick (easy way to check is to check the info for the memory stick on your PSP if its says that MAGIC GATE is unknown rather than supported then it is fake.
The fake ones typically double compress the data so that it appears to have 8GB when in reality it does not.
Nov 15, 2008 | Sony Memory Stick PRO Duo (2GB) for PSP
M2 to memory stick pro adapter
Plug the duo card into adapter labels need to face same direction. Plug adapter into camera or other device label facing you. Once card is installed make sure you format it for the device. My memory stick is 8GB and I use it in my P200 cybershot camera. 2400 high quality 7mega pixel images and 42min-3hrs of mpeg video.
Sep 09, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
Sony Cyber-shot DSCW210 Digital Camera Logo
85 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
